Old 01-04-2021, 05:02 PM   #1
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Front bushing leaking ?
Both my lower front bushings look like they're leaking. Can they even leak? This is the only 2 areas that show a sign of a leak. Its all dry so has not happened recently. mileage is 18K and only 50 track days with the last year on g3R tires
Old 01-04-2021, 10:30 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Possibly? There are hydraulic bushings in existence but I didn't think the 1LE used them. Could be wrong there though. Also curious how it got on parts above the bushing if that's where it came from.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 01-05-2021, 10:16 AM   #3
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Front FE4 link bushings are hydraulic - that's what is leaking. Just replace the links with the FEA (ZL1 1LE) ones that are not hydraulic and were meant for the G3R's you are using. PN's 84051643 (L), '44 (R).
RUQWIKR is offline   Reply With Quote
Old 01-05-2021, 02:13 PM   #4
Tim M
Drives: 2018 Camaro SS 1LE
Interesting...
Tim M is offline   Reply With Quote
Old 01-05-2021, 07:03 PM   #5
carguy55
carguy55's Avatar
Thanks
Old 01-06-2021, 09:41 AM   #6
carguy55
carguy55's Avatar
Don't forget to get new bolts which the service manual says are TTY. Interesting that the FEA arms are $30 less than the FE4
Old 01-06-2021, 11:27 AM   #7
Mountain
Mountain's Avatar
And 3 years later, someone who's had the FE4 front radius links in hand finally takes a good look at what they are.
I've been wondering why the FE3 bushing was so different (and more expensive) than the FE2/FE3/FEA bushing...
The only reason I can think of why GM would do this would be related to NVH, but why and why on the ZL1 and SS 1LE? My thinking is that it must be related to something with the MRC struts: Maybe them being structurally stiffer, accompanied by the spherical-jointed lateral link, required something a bit softer to go on somewhere...
Anyway, thanks for posting up!
Old 01-06-2021, 12:09 PM   #8
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
NVH is my vote on why as you stated. Hydraulic ones would be better for isolating smooth road shake, for example.
Old 01-06-2021, 04:15 PM   #9
carguy55
carguy55's Avatar
The other choice was the SPL arms for only $700 lol
Old 01-08-2021, 12:53 PM   #10
tmalaquin
Drives: Blue ss 1le 18
My guess is the 20inch wheels from the SS 1Le and ZL1 are heavier than other variants and generate shake / vibrations when they are exited at their modal frequencies (12 to 20Hz), hence the hydros to damp it. Wheels and tires are the heaviest mass components of our suspension.
tmalaquin is offline   Reply With Quote
Old 01-14-2021, 07:06 PM   #11
carguy55
carguy55's Avatar
Finally got the new FEA links. $30 each cheaper than the FE4
Old 01-15-2021, 06:08 AM   #12
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Wonder if it would be worth it to have a place like kingpin machine put a spherical bearing in our stock control arms... It's gotta be cheaper than what SPL is charging for their LCA.
That1guy_tim is offline   Reply With Quote
Old 01-15-2021, 02:54 PM   #13
Mountain
Mountain's Avatar
BMR has a replacement spherical option - they aren't "cheap" but also not outrageously priced. The P&M GT4.R runs sphericals, as well, and you can buy those arms, but they are $$.
Old 01-16-2021, 08:52 AM   #14
That1guy_tim
Drives: Camaro 1ss
Thanks for that info 180$ isn't a bad deal at all. Might jump on these
