01-06-2021, 11:15 AM | #15 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
A crooked steering wheel is often tied to thrust angle being off in the rear. The car crab walks and the front wheels naturally track straight, so the steering wheel is off center.
On my car, front alignment never moves, but rear toe does (common on these cars). You can always tell when the rear moves because the wheel is off-center.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
01-06-2021, 02:13 PM | #16 |
Drives: 2021 Chevrolet Camaro SS 1LE Join Date: Dec 2020
01-25-2021, 02:53 PM | #17 |
Drives: '20 SS/1LE Join Date: Jul 2020
Add my 20 1le to the crooked steering wheel list. Dealer said the same thing about the suspension setteling and gm wouldn't pay for an alignment until I hit 2500mi unless there was something damaged. At least the service manager drove it around the lot and put it up on the lift he then agreed that the wheel was off center but not pulling or anything. Basically I'll make a note and bring it back after you hit 2500.
01-25-2021, 03:00 PM | #18 | |
oh im located in hb/oc
01-25-2021, 03:46 PM | #19 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
01-25-2021, 04:14 PM | #20 |
Well if I'm going straight on a smooth road with no steering input the wheel will be turned to the left about 3°. I really don't think the alignment is off a bunch because if I let the wheel go it stays going straight and doesn't pull left or right.
01-25-2021, 05:05 PM | #21 | |
Drives: 2018 1SS 1LE Join Date: Dec 2012
01-25-2021, 05:15 PM | #22 | |
get the spl toe rods i have them never been happier adding the rest of the kit next month
01-25-2021, 05:52 PM | #23 |
What I meant was, turn your steering wheel so it is centered. It will pull then.
01-26-2021, 07:46 AM | #24 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
That's not a pull - it's just a toe misalignment. A pull is when the car turns if let go of the steering wheel, or when you have to add force to the steering wheel to keep it from turning.
Matt Miller
2020 SS 1LE |
01-26-2021, 08:18 AM | #25 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Isnt an alignment in the "free" category up to 12 months/12K miles? Not that they just do it but I thought that was a warranted/covered item in that time.
01-26-2021, 08:45 AM | #26 | |
Pull=effect The proper static position of the steering wheel, when going straight, is straight and level. In VINCETHEGIANT’s case, if held at that point, then it’s going to walk, move or whatever we want to call it. Either way the service manager recognized it and should have had it fixed.
01-26-2021, 06:19 PM | #27 | |
*This is the case for even the generic, non-car-specific definition of the word "pull."
Matt Miller
2020 SS 1LE |
01-26-2021, 07:24 PM | #28 |
What do you call it when you hold the steering wheel straight, and the car moves in an unintended direction?
We are arguing over semantics. I agree with your correction to the problem. My point is that we will use a straight, level steering wheel as a static base point. The reaction of the car from there is going to dictate the solution.
