Old 12-12-2020, 07:20 PM   #1
Camaro227
Camaro227's Avatar
Drives: Toyota Puris
Which hose is this?
The one circled in the picture. It looks a bit oily greasy? I did have my car oiled for the winter...
Camaro227 is offline   Reply With Quote
Old 12-12-2020, 09:08 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Oil cooler lines
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 12-13-2020, 08:54 AM   #3
Camaro227
Camaro227's Avatar
Originally Posted by Camaro2ss2010 View Post
Oil cooler lines
Thanks
Old 12-15-2020, 09:51 AM   #4
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
Those are transmission cooling lines. Follow the path to see where they are connected. There's no oil in those lines. I had to disconnect when I did my cam swap.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
