09-19-2018, 05:48 PM | #1 |
Camaro LT1 to LT4 blower swap.
Hello all!
I’m new to forced induction. I bought an LT4 blower with some accessories. Included are PICS of everything I have. I really need somebody to help me out and tel me everything I’m missing. I have a connect to get OEM parts. Aftermarket parts please advice where to get them. Thanks in advance!!
2015 Camaro 1ss M6
Stage 4 BTR Cam FBO 500 W/HP N/A Build -----SOLD----- 2017 Camaro 1ss A8 P1x Procharged Texas Speed long tubes 624WHP----572wtq --------SOLD--------- 3 year break- Had twins LOL. 2010 Camaro 2ss M6 Stock... Not for long |
09-19-2018, 06:45 PM | #2 |
Looks like all the important stuff is there. You'll need a relay and some wiring for the pump If you are local to us we can install it and dyno tune it for you.
09-20-2018, 07:55 PM | #3 |
Bump for help
2015 Camaro 1ss M6
09-21-2018, 05:40 AM | #4 |
Drives: 2018 Camaro SS Join Date: Sep 2009
09-21-2018, 10:05 AM | #5 |
Dyno Show Queen LOL
I would use the dual pass heat exchanger from eforce instead of the stock one or similar.
1. You need to address the PVC valve issue (use a LT4 valley cover or plug the hole in the supercharger provided there is enough clearance between the LT1 cover and the Lt4 blower. 2. I know on my SS I had to change fuel lines when the eforce was installed could be a clearance issue 3. Harness from the MAF to Map sensor again use the Eforce premade cable. 4. I would add a some type of fill tank even though the LT4 doesn't it will be less complicated to get the air out. 5. I maybe swiss staken but you will be at 9.1 boost with that combo If that is a lowerstock LT4 balancer and stock upper.. ( this is where ADM or someone else that does alot of conversion should help ya right!)
09-25-2018, 11:25 AM | #6 |
Drives: 2016 NFG SS A8 Join Date: Jul 2014
As stated, you will need the LT4 valley cover for pcv or deal with it another way. The bottom of the blower has a hole for the LT4 valley cover to go in to pull the crank case pressure out.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
10-13-2018, 11:02 AM | #7 |
Drives: 2016 Camaro 1SS Join Date: Feb 2018
Looks like you need the adapter plates for the blower to Head connection, you need the LT4 lower radiator hose..... if you need instructions pm me, I have them on a pdf file.
Ray |
10-29-2019, 07:02 PM | #8 |
Drives: Camaro 2Ss Join Date: Oct 2019
I could use them if you still have them
10-31-2019, 03:04 PM | #9 |
Drives: Chevrolet Camaro Join Date: May 2019
Razor427 I sent you a pm as well. Thanks.
10-31-2019, 07:41 PM | #10 |
If anyone has the instructions for this swap hit me up. Thanks.
10-31-2019, 08:55 PM | #11 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
You do not need the adapter plates if you get our machining service on the LT1 cylinder heads.
https://store.katechengines.com/cnc-...eads-p844.aspx |
03-27-2020, 05:54 PM | #12 |
Drives: gen 6 Join Date: Mar 2020
I'm having the same issue. I have a 2017 camaro ss . Does anybody here have a parts list as to what exactly is needed
03-27-2020, 06:18 PM | #13 |
silverado53 did you find all the parts needed to do the conversion
04-08-2020, 04:20 PM | #14 |
Drives: 2017 ss1 camaro Join Date: Apr 2015
