Old 07-25-2018, 07:42 AM   #15
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
Originally Posted by yotaman96 View Post
Doesn't seem like a wheel or tire issue. It only happens at part throttle for me. No vibrations while just cruising.
same for me only when I'm accelerating from 3-4 gear
Twoblindsheep is offline   Reply With Quote
Old 08-04-2018, 01:18 PM   #16
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Originally Posted by Miami_1LE View Post
Its in relation to the speed. Sounds like its coming from the rear. And I get vibration in the steering wheel, pedals, and ass. The vibration is not something out of this world but I do know its not suppose to be there. I'm gonna jack her up and check out the axle bolts. I take really good care of my car and don't beat the hell out of it. Also, lets say I'm in 3rd gear at maybe 2000rpm, if i floor it i get vibration while going up through the rev band. All gears feel like this, and is mostly felt in gears 2-4 because that's where I usually hit it.
Mine did this and went away when driven. Sits for a coupe weeks it returns then goes away. Bet your paycheck its tires.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 08-04-2018, 03:31 PM   #17
Move_Over
Drives: ISO ss 1le
Not sure if it’s an issue, a lot of people have it.
https://www.camaro6.com/forums/showt...Vibration+gear
Move_Over is offline   Reply With Quote
Old 08-06-2018, 09:37 AM   #18
Firerader
Drives: 2017 50th Anniversary/Hennessey
Vibration
After some hard acceleration runs this weekend I'm feeling the exact same thing. The wheels and tires are only a couple weeks old. I can see where a small stick on wheel weight may be missing from a rear wheel. I hope that's all it is. I really feel the vibration pulling through 4th gear and up. I also noticed the (M6) shifter shacking more than I remember.
2013 2SS/RS 1LE.
Firerader is offline   Reply With Quote
Old 08-17-2018, 02:37 PM   #19
Nvr2tall4SS
Drives: 2017 Camaro 2SS
my 17 SS vibrates between 50 and 60. Nothing before and nothing after. Its almost violently shaking. Going to get a balance this weekend and hope it fixes the issue.
Nvr2tall4SS is offline   Reply With Quote
Old 09-04-2018, 10:41 PM   #20
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
Mine does the same but not all the time. One pull it does the other it doesn’t. More at part throttle and low/medium rpm, mainly in 3-4 rd gears. Seems to dispear and high rpm. Seem to be driveshaft related to me...
Nabush is offline   Reply With Quote
Old 09-07-2018, 01:49 PM   #21
n12k1
Drives: V6 2LT Camaro Overkilled
I am experiencing some shaking and vibrations in my car,when i put in neutral while cruising it still shakes,but i am not sure if it's a transmission problem,or there is something else wrong,because the roads are full of potholes and sometimes hit them hard.....I also feel the shaking in my steering wheel,and the car shifts smooth The car is built december 2015 and has 32k miles and has the A8
n12k1 is offline   Reply With Quote
Old 11-05-2018, 09:35 AM   #22
Nabush
Did someone got it to the dealer and found a fix ? It's annoying….
Old 07-15-2019, 06:22 PM   #23
appleman22
Drives: 2017 1ss 1le
anyone ever fix this?
appleman22 is offline   Reply With Quote
Old 07-18-2019, 03:15 PM   #24
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
I had posted about a similar vibration when the car was new but only at or above highway speeds, turned out to be my r/s axle nut was like 1/8 of a turn loose so i hit both sides with a 1/2in air gun amd my vibrations havent returned.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 08-25-2019, 03:29 PM   #25
appleman22
any updates on this vibration guys?
Old 08-26-2019, 07:04 AM   #26
Chris C 1SS 1LE
Drives: 2017 1LE
Wheels TQ to 140?
Old 08-26-2019, 11:24 AM   #27
appleman22
yeah
Old 08-28-2019, 08:39 AM   #28
Chris C 1SS 1LE
Drives: 2017 1LE
FWIW this thread has some age on it. Mine has stopped altogether some time ago. 11,200 mules on it.
