04-21-2017, 08:42 PM | #1 |
Drives: 2016 Red Hot Camaro 1SS A8 Join Date: Jun 2016
Weak start with hot engine
My starter sounds very weak and barely cranks when the engine is hot. There is no problem when the engine is cold. Last time I left it with dealer and they said they couldn't duplicate the problem. I remember my 88 Mustang was doing this and it was a starter problem. Anyone else encounter this in their SS? So far the dealer has done nothing about my noisy rear and the weak start. I think I'm going to try a different dealer.
04-21-2017, 09:56 PM | #2 |
Drives: 2016 Camaro 1SS Join Date: Jan 2016
Mine has done this for quite some time now too but I haven't taken it to the dealer for it yet. It's a pain with my schedule to get to the dealer. There have been times after shutting it off after say a 45 min drive, then cranking it back up 5-7 min later, that it nearly won't turn over at all. But thank God even when it does it really bad it eventually still does turn over. Seems like starter heat soak maybe?
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
04-21-2017, 10:48 PM | #3 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Mine does this between auto-x runs but has never NOT started so seems to be pretty normal.
04-22-2017, 02:31 AM | #4 |
Drives: X-15 Velocipede Join Date: Mar 2008
Protective heat source barrier to prevent heat soak conditions
https://www.amazon.com/010402-Versa-...er+Heat+Shield
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
04-22-2017, 03:38 AM | #5 |
Drives: 2SS '16 Camaro Join Date: Apr 2016
Same deal here, but it has always started so I haven't taken it in. Normal?
'16 2SS White/Adrenaline Red Coupe Mag ride, 8-speed, Sunroof, Dual-Mode Exhaust, Black wheels
Also: 2010 ZR1 2018 GT3 2013 LX570 |
04-24-2017, 11:37 AM | #6 |
Drives: 2ss Nightfall Grey Join Date: Dec 2016
I've experienced the exact same occurrences with my Corvette and NSX, so no worries.
04-24-2017, 12:50 PM | #7 |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
happens to me as well ... slow crank when engine is warm. I figure it is still under warranty so I don't worry about it.
04-24-2017, 08:27 PM | #8 | |
Drives: 16' Camaro 2/SS BlackMosaic A/8 NPP Join Date: Jan 2016
04-24-2017, 11:20 PM | #9 | |
This heat shield should help the problem and extend starter life. Exhaust is baking that poor thing. Installation? Not sure - general auto repair shop, performance shop, anyone with a lift you would trust. Be sure they lift it properly (google site search).
04-25-2017, 12:48 PM | #10 |
Drives: 2017 ZL1 Join Date: Oct 2016
This was a complaint in one of the car mags - when they reviewed it against a m4.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
04-25-2017, 06:34 PM | #11 | |
04-25-2017, 09:21 PM | #12 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Hold the start button for a few seconds before engaging the clutch. See if that helps. Appears to do so for me.
Could this be a fuel pump priming issue? Don't think it's the starter. |
06-28-2021, 03:18 PM | #13 |
This is not a normal condition. it's called heat soak and it can cost you if you don't get it taken care of while under warranty.
you can google it, but heat soak happens when a car sits for a short time after being driven. the solenoid absorbs heat from the engine block, exhaust manifold, and even hot pavement under the car. when the solenoid becomes heat soaked, it gains resistance and the battery won't turn the starter. This can damage the battery, negative lead to the solenoid, the starter, and related components including the fuse block on a 6th gen. Typical cost to repair is over $1,000. Get it checked out while under warranty. There is a class action lawsuit pending and they need more people to come forward who have experienced this problem. google it and you'll see it documented everywhere.
2SS Nightfall Grey / Black Rally Stripes / Sunroof
NPP / MRC /1LE Suspension / Nav / M6/ Xpel'd / CAI |
06-28-2021, 04:00 PM | #14 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Thread Tools | |
