03-29-2017, 04:27 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2015
Flashing Check Engine Light
Hey guys, just started my car after work and the check engine light came on and blinked for about 30 seconds then remained off. Does anyone have any idea on what this could be? I tried checking the code but nothing was there.
03-29-2017, 05:04 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
Flashing check engine light would normally mean there is a misfire. Which engine?
03-29-2017, 05:09 PM | #3 |
Oh that would help. This is on the LT1. I have just recently installed my ported throttle body and Intake manifold.
03-29-2017, 07:18 PM | #4 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
This happened to me when my hesders burned a spark plug wire. Something Is wrong. Thr flashing lights I was told means stop driving immediately to prevent damaging motor.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
03-29-2017, 07:28 PM | #5 |
I would imagine if it was that bad that the cel would remain flashing or stay lit
03-29-2017, 07:29 PM | #6 | |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
funny we have this huge DIC screen to tell us what song is playing, or when to shift to 4th gear, but it won't explain the BLINKY CEL light? |
03-29-2017, 07:29 PM | #7 |
Google it. I knew a gm mechanic who told me what it meant. I don't know for sure.
1ss/Auto-Hyper Blue
03-29-2017, 09:04 PM | #8 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Flashing check engine light is the misfire notification. If it starts and goes away then it is a random misfire, if it continues and wont go away then stop driving. Check all of the coil pack connections and spark plug connections, pretty easy. If it comes up again I would get with the dealer.
Can be caused by a spark issue, bad gas and several other things. |
03-31-2017, 08:13 AM | #9 |
Drives: 2017 Camaro 2SS Join Date: Dec 2016
Well, my car decided to start flashing the check engine light this morning. It began right after entering the freeway. The light flashed on and off for about 30 seconds and then remained off. When I got to work I checked the plug wires and all seemed to be in order. I will be getting some fuel treatment after work and hopefully it does not continue. I just got my car back Tuesday from being at the shop for a transmission shudder!
03-31-2017, 08:25 AM | #10 |
Drives: 2017 camaro SS blue w/white stripes Join Date: Nov 2016
KEEP US INFORMED!!
Thanks |
03-31-2017, 12:04 PM | #11 |
Talked to my service advisor. He stated at this time there is no need to worry.
He said if the check engine light comes on and flashes for only a few seconds it is most likely a low voltage situation. Tried to put it on them flushing the transmission fluid last week. We will see. If the light comes back on when I leave work I will be back in a loaner again! |
04-01-2017, 08:13 AM | #12 | |
Ok, time for you to find a new service advisor. For GM vehicles a flashing "Service Engine" light has be a P0300 - Engine Misfire Detected indication since OBDII came out. It even states it in the owners manual to that affect as well. And dealers wonder why owners are reluctant to take their vehicles into them for work these days. |
04-01-2017, 09:17 AM | #13 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Check all of the coil harnesses to make sure one did t get stressed when you did the intake swap. If you can borrow a scanner you should be able to isolate which cylinder it is.
07-12-2017, 09:42 AM | #14 |
Drives: Traded in 2016 BLUE VELVET 2LT RS Join Date: Aug 2016
Down in Florida on vacation, found a nice quiet road, so did a run up to 100, the flashing check engine light occurs. This makes the second time I have seen this happen. I will have it checked once I get back home. Did a few acceleration tests while pulling onto I4 and no flashing.
