Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 06-24-2016, 09:08 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro SS Borla X-Pipe with Mid Pipes 60606 Cat Delete
2016-2018 Camaro SS Borla X-Pipe with Mid Pipes 60606 Cat Delete
2016 Camaro SS 6.2L V8, Automatic/ Manual Trans Rear Wheel Drive 2 door.
This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It does not include AFM valves.
X-Pipe without AFM (secondary cat-delete; competition/racing use only); This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It does not include AFM valves
Item # 60606
Website Link : http://www.rpidesigns.com/shop/item....06-cat-delete/
RPIDon is offline   Reply With Quote
Old 06-24-2016, 10:09 AM   #2
Joshfrisco
Drives: 6GC
Does this X-pipe bolt up to the factory exhaust manifolds and NPP?
'16 Jet Black 2SS | A8 | MRC | NPP | NAV |
Joshfrisco is offline   Reply With Quote
Old 08-11-2016, 08:07 AM   #3
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It should bolt up to the factory NPP mufflers.
RPI Designs is offline   Reply With Quote
Old 05-08-2017, 02:18 PM   #4
JeromeS13
Drives: 2017 1SS/1LE
It does, but you'll need two of these style clamps:
https://www.summitracing.com/parts/vpe-1176
Old 10-16-2017, 01:44 PM   #5
RPI Designs
2016-2017 Camaro SS 6.2L V8, Automatic/ Manual Trans Rear Wheel Drive 2 door.
Old 10-16-2017, 02:26 PM   #6
Bow Tie Affair
Drives: 6th. Gen ZL1
Item # 60606
You have the wrong picture and link posted. Here is the the link to part# 60606.
https://www.borla.com/products/camar...rt__60606.html
Bow Tie Affair is offline   Reply With Quote
Old 10-17-2017, 01:36 PM   #7
RPIDon
RPIDon's Avatar
Drives: Camaro
Fixed.
Thanks, for catching that.
Old 10-19-2017, 05:31 PM   #8
Bow Tie Affair
Fixed.
Old 10-06-2018, 03:47 PM   #9
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 07-04-2020, 02:10 PM   #10
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
Would the 60607 bolt up to an MBRP axle back on a 2017 SS 1LE? Or would you need an exhaust clamp reducer 3" to 2.75"?
JTRATX is offline   Reply With Quote
Old 07-04-2020, 06:03 PM   #11
Drizzt ss
Drizzt ss's Avatar
Drives: 2017 NGM 1SS MRC NPP
These in stock?! The 60606? If so I’ll order right now, I know this post is a little on the older side...
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
Drizzt ss is offline   Reply With Quote
Old 05-09-2021, 09:22 AM   #12
whynotlikemike
Drives: 2018 Camaro
It says discontinued, how would I purchase?
whynotlikemike is offline   Reply With Quote
Old 11-10-2021, 04:00 AM   #13
1lE_1LE
1lE_1LE's Avatar
Drives: '21 M6 1SS 1LE
perhaps there's an issue with your site but like whynotlikemike inferred, there's no buy now button
1lE_1LE is offline   Reply With Quote
Old 07-24-2022, 01:00 PM   #14
RPI Designs
