10-20-2013, 09:29 AM | #1 |
Drives: 2013 2LS BLK Join Date: Oct 2013
Catch can benefits
I am doing a paper in college about engine sludge, and how terrible it is for your engine. Basically everything that a catch can helps eliminate. I see a lot of people on here with great information! I just need the source you get it from! So that I can use it as a source in my paper. As I have to have 3.
10-20-2013, 09:39 AM | #2 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Not sure how you would reference a thread from this web site but here's a good source of info Apex Chase put together.
http://www.camaro5.com/forums/showthread.php?t=284219
10-20-2013, 11:49 AM | #3 | |
10-20-2013, 12:49 PM | #4 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
PURPOSE OF YOUR STOCK PCV SYSTEM
The PCV (Positive Crankcase Ventilation) system is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. The PCV system routes crankcase fumes into the intake manifold where they can be burned to eliminate harmful emissions into the atmosphere. The PCV valve controls the amount of crankcase flow volume depending on the engine's load. With large throttle openings (high engine loads), the more blow-by gases are produced, and the more the PCV system flows oil vapor in to the intake manifold. The PCV valve also functions as a check valve to prevent intake manifold flow from reversing back into the crankcase when there is a backfire, or during periods of high manifold pressure (boost) during forced induction by turbocharger or supercharger. NEGATIVE EFFECTS OF YOUR STOCK PCV SYSTEM Many Corvette, Camaro, Firebird and GTO owners with LSX engines can testify to the amount of oil residue that can accumulate inside the intake manifold, throttle body, intake track and even the air filter during aggressive driving conditions.There are various negative effects when excess oil vapor contaminates the intake system from the stock PCV system - such as:Throttle body and/or MAFS (Mass Air Flow Sensor) malfunction or failure.Air filter, intercooler (if equipped) and intake ducting contamination if oil pools and run back out the intake system after engine shutdown.Reduced octane of the air/fuel mixture, which can cause detonation and the ECM (Engine Control Module) to retard timing, thereby reducing engine power.Excessive carbon build-up on valves, piston crowns, combustion chambers and spark plugs. This also increases the chance of detonation and power loss.Increased emissions & possible contamination of catalytic converters and oxygen sensors.Bottom Line:*Excessive amounts of oil vapor in the intake manifold is detrimental to your engine!Solution:*Install the E2 Elite Engineering PCV Oil Catch Can! ULTIMATE FUNCTION The E2 Elite Engineering PCV Oil Catch Can is designed to effectively separate oil from the crankcase vapors, thereby eliminating all negative effects of excessive intake system oil contamination. Our Catch Can has been engineered to remove the oil vapor before it has a chance to contaminate your intake system.
10-20-2013, 04:45 PM | #5 |
Drives: Camaro 2SS/RS Join Date: Sep 2013
Check your references/sources. The ones listed here are by the ones making and selling them.
Also try to find an independent person who has no "skin in the game" either way, and maybe some who have bought one and not noticed any effect or any real residual oil in the can chime in. (Then again, after spending $150+ for an aluminum can with a few hoses, they aren't likely to admit they were scammed). You can also try writing GM directly, or the engineering dept to see if you get a response, but either way, when you do an academic research paper, if I was your Prof, I would be asking for both references. Good luck. N |
10-20-2013, 06:43 PM | #6 |
SYBIL
Catch cans a scam? Not hardly, the Elite Engineering catch can works just as they describe in my above post. The catch can was my very first mod when i bought my camaro, and i now have a little over 20k miles on it. Somewhere around 16k i had my throttle body taken off and polished and it along with my intake were still shiney new and bone dry. Mine collects a couple ounces of oil and has to be dumped at every oil change.
10-20-2013, 06:46 PM | #7 | |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
T2 Facia, ACS TL1 Hood, ACS Winglets. G5CR CAI. Hotchsic Strut Brace and more...
10-20-2013, 06:46 PM | #8 |
Good thing it's a paper and no lab testing.
Tags |
catch, elite, engine, sludge |
