11-03-2015, 05:45 PM | #1 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Amsoil or LS30?
So There still seems to be alot of different Thoughts on Oil for a cammed car.
Im leaning to Amsoil or LS30. Pros cons on either? I was about to pull the trigger on Amsoil, but I called a local rep and he is selling to me the same price I can get online as a preferred customer. So I asked if he got a discount on shipping, he said it would be the same shipping charges. He wanted me to order it from him so he got the credit too. So why would I order through a local rep and not just buy direct. Kinda pissed me off and now i've started to question their practices at Amsoil. So now I'm leaning more towards the LS30. Thoughts on which is better? |
11-03-2015, 09:53 PM | #2 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
So are you concerned about price, shipping or what is best for a cammed LS engine?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
11-04-2015, 04:51 PM | #3 |
KNGTFALL
I want whats best for a cammed LS engine.
The shipping/price thing was just a concern over business practices. From what I see on their site. Amsoil gives a discount on shipping on orders over $100 or a discount for preferred customers, but not both. I can order the oil without the help of a local dealer, and end up getting it for the same price. So why would I use them to get it, what is the incentive? Anyway, i've read about Amsoil and LS30 being the top 2 for cammed LS3s. A couple of others as well, I seen that you recommend redline but I don't know enough about them or what kind to get. I don't want a race oil, but a street oil. I still have CATs as its a daily but do drag the car once a year. What Should I get? |
11-05-2015, 10:20 AM | #4 |
Drives: 2014 Crystal Red 1LE 2SS Join Date: Jun 2015
Here's the way it was explained to me. Zrod is excellent for a car that sits and is not a dd because of the anti corrosion additives. If you dd and are not concerned about this then the Amsoil sig series oil will do just fine, although the zrod does have a little higher zinc/phosphorus content.
As far as ordering...my amsoil contact told me to become a preferred member and order direct. So that's what I do. |
11-10-2015, 10:36 PM | #5 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Both are good. After my cam install, I went with BR30 for breakin and LS30 after that. LS30 is geared towards the LS series engines...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-11-2015, 12:44 PM | #6 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
I have been using LS30 since my cam install. I buy it by the case
11-11-2015, 01:36 PM | #7 |
LS30 on Amazon Prime, 2 day shipping free
11-12-2015, 02:10 PM | #8 |
Nothing but good luck with LS30. Been using it since the first oil change. 4 cams later driven hard and a DD everything looks good. I don't run cats but I have heard from others it hurts them. Take it for what it's worth.
I would not run anything different unless I had no other choice.
11-13-2015, 03:47 PM | #9 |
KNGTFALL
Thanks guys I went with Amsoil for now, still worried a bit about fouling the CATs.
Plus I ordered back on the 6th before everyone chimed in. LOL Anyone have issues with the higher ZDPP in LS30 affecting the sniffer part of emisions testing? |
11-14-2015, 05:39 PM | #10 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
I was going to ask that same question .
11-15-2015, 03:19 PM | #11 |
I get inspected without cats here.... If you pick the correct inspection station where they don't do a visual you have nothing to worry about as long as you don't have a CEL. With cats you should be good to go.
11-21-2015, 10:56 PM | #12 |
The benefit of a Amsoil dealer is that he has it in stock. If he doesnt stock it just get a prefered account. Amsoil dealers get it at the same price you can get it for. Anyone can be a dealer. You want ZRod 10w30 for a cammed car. both are good oils. ZRod is not just for cars sitting around. It has additives that work well if your car is stored but it is meant for any car that needs the added ZDDP as with a cammed car. DD or not. It will not harm your cats.
11-23-2015, 05:07 PM | #13 | |
KNGTFALL
I still run CATs and use a Lenient inspection station, but they still run the sniffer test. I hope the higher levels of Zinc wont fail me. |
11-23-2015, 05:31 PM | #14 |
I don't think it will.
