Old 12-28-2020, 04:11 PM   #1
Crazy Drywall Guy
Drives: 2018 Chevy Camaro 1ss
New headers and steering issues?
So I just finished up my kooks longtube header install. I had the steering shaft unhooked at the time and had my son start the car for me to check for leaks and he spun the steering wheel a couple times! Luckily I had marked the shaft position before this. The service steering/stabilitrack is now on. Even though I know the it's hooked up in the original position,will spinning the wheel freely throw off the calibration somehow?
Crazy Drywall Guy is offline   Reply With Quote
Old 12-28-2020, 04:49 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
what brand/size?
Old 12-28-2020, 04:52 PM   #3
Crazy Drywall Guy
what brand/size?
2"Kooks?
Old 12-28-2020, 04:55 PM   #4
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Your clock spring is fooked, never move the wheel with the shaft disconnected.
https://www.tascaparts.com/oem-parts...pring-84205927
Warrior102 is offline   Reply With Quote
Old 12-28-2020, 04:58 PM   #5
kropscamaro16
Originally Posted by Warrior102 View Post
Your cock spring is fooked, never move the wheel with the shaft disconnected.
lol cock or clock spring?
Old 12-28-2020, 05:21 PM   #6
Warrior102
Warrior102's Avatar
Oops, fixed.
Old 12-28-2020, 06:05 PM   #7
Crazy Drywall Guy
New Cock spring is on order. Thanks 👍
Old 12-28-2020, 06:10 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Do you have odb tool that can read steering angle or can you check it from DIC (digital instrument cluster)?
That way you can possibly reset steering angle to zero and reconnect shaft at proper clocking.
ing for grip.
http://www.motorsportsne.com/
Old 12-28-2020, 06:22 PM   #9
CHASLT1
Drives: 2021 Camaro LT1
I never had to order a cock spring.
CHASLT1 is offline   Reply With Quote
Old 12-28-2020, 06:32 PM   #10
Crazy Drywall Guy
I don't have a odb tool😞. Probably wouldn't be to hard to pop one of the shaft bolts out and fiddle with it to seeing If I can get it set back to zero.
Old 12-28-2020, 06:42 PM   #11
Warrior102
Warrior102's Avatar
Originally Posted by Crazy Drywall Guy View Post
New Cock spring is on order. Thanks ��
I just noticed you have a 1SS, not sure if that has a heated steering wheel the part number I posted was for a 2SS. Disconnect the battery for 15 - 20 min before removing the airbag. Also do not attempt to remove the torx retention bolt with anything less than a Snap-On, Mac or SK quality bitt as GM uses a nuclear loctite on it, if you strip that you'll be replacing the steering column if you have to cut it.
https://www.tascaparts.com/oem-parts...YtMmwtdjgtZ2Fz
With the wheels pointed straight ahead and the wheel centered do your back up camera guidance lines point straight or off to one side? If it's not straight you may be able to just reset the steering angle sensor like Vtor_ZL1 mentioned.
Old 12-28-2020, 06:46 PM   #12
Crazy Drywall Guy
I went on eBay and found one for a 1ss W/0
Heated steering. Thanks for the tip
