09-04-2020, 09:10 PM | #1 |
Drives: 2018 Camaro SS Join Date: Apr 2019
Ticking Noise, fairly confident it's a lifter. (Video Link Included)
Hey Guys,
I did some browsing on the forums here, and I couldn't find any clear cut answers and I'm looking for some confirmation. 2018 1SS M - 18500~ miles The car just has kooks LT, and an e85 tune and I honestly baby it and hardly drive it. Couple mornings ago I was driving just to get some gas, and I noticed a ticket noise much louder than the typical DI noise which can be heard from outside, and within the cabin consistently. https://drive.google.com/file/d/1JAb...ew?usp=sharing I've parked the car and haven't driven it since, I'm just playing it safe. Unfortunately because of the tune and headers my warranty is out the window. If it is the lifter, I'm fine with replacing it and I'm not interested in camming the car at this time. I'm just unsure what my options are when it comes to replacing the lifters, am I just stuck getting AFM ones as replacements or do I have other options with the stock cam? Any advice is greatly appreciated. |
09-05-2020, 06:31 AM | #2 |
Drives: 2017 ZL1 Join Date: Apr 2020
Your warranty is not out the window. Headers are fine. Take the tune back to stock Exhaust leak ? Did you use gm exhaust gaskets ?
2017 ZL1 M6 Silver Ice Metallic
09-05-2020, 07:30 AM | #3 |
Much of the times these ticks and clicks we hear are probably normal operation or maybe a header leak. I don't think that is the case for you unfortunately. To my ear that indeed has a very mechanical valve train sound much like a lifter/push rod. However as mentioned its worth eliminating the possibility of a header exhaust leak. I've seen a lot of people fix their engine ticks with a new set of exhaust gaskets.
The headers, tune and e85 sensor certainly can cause a dealership to deny warranty work. But who knows - some dealerships are willing to turn a blind eye to mods that are not likely to be directly related to the issue. I'd say take it in - no harm in asking - until you do the answer is by default "no". Good luck and keep us posted.
09-05-2020, 07:40 AM | #4 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
Get a long piece of vacuum hose, with one end ant your ear, move the other end around the headers. |
09-05-2020, 07:46 AM | #5 |
Once again, headers will not void your warranty. GM performance parts sells arh for our cars. The Magnuson moss Federal warranty act protects you.
09-05-2020, 08:41 AM | #6 |
Drives: 2017 2SS Manual Join Date: Apr 2017
The tune most certainly will void warranty if the dealer wants it to
09-05-2020, 09:27 AM | #7 |
Drives: 2018 ZLE Join Date: Feb 2018
I agree 100% but some dealers overlook it and some will find anything not to fix something. My dealer told me any system I mess with is voided, so if I did headers anything in the entire exhaust system is on me. My brother Silverados engine had to be replaced and the dealer did it even with a tune and exhaust here in South Fl
09-05-2020, 03:43 PM | #8 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
check your spark plug wires. you may have a loose one. there are multiple people who did work in the engine bay and developed a tick. i has turned out on several guys cars that it was a simple loose plug wire. it makes a hellaof a tick
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
09-06-2020, 06:18 PM | #9 | |
I'll definitely check them again though, as well as the spark plug wires. I had my father come over and listen to the car today, hes got a lot of experience with engine work and he thought it sounded mechanical as well, but he thought it was very minor at this time and that I caught it very early. I have read some horror stories on here of the AFM lifters collapsing and causing serious damage, so I don't want to take any chances. I just hope nothing else is damaged, and I can just replace the lifters if that's the issue. All that aside, are the OEM AFM lifters my only option with the stock cam? |
09-09-2020, 07:47 AM | #10 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
09-10-2020, 07:40 AM | #11 | |
As far as the dealer goes, on a modified car, the only thing really up to them is if they want to work on it. As far as the warranty goes, if it's something that doesn't really need GM's direct approval, often something very minor, or a TSB or recall, as long as GM doesn't request an ECU readout, they'll probably handle it. Again, on a modified car, that is up to dealer policy. The main reason a dealer may refuse to work on a modified car, isn't so much about warranty as it is liability. Since it is modified, they do not know what exactly, who exactly, and how exactly all of that was done. Once they take it in, and if something happens to the engine while in the shop, for whatever reason, it opens a pandora's box of blame and legal liability. Many dealerships may tell you to take it back to the shop that did the modifications since technically, it's more their engine than GM's at that point. |
11-08-2020, 04:34 PM | #12 |
For those that were still interested in knowing how this played out, it ended up being a corroded spark plug wire, I know in the video it sounds very metal on metal, but a new spark plug wire and the car started running perfectly.
11-08-2020, 05:01 PM | #13 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Check your plug wires first.
11-08-2020, 05:54 PM | #14 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
I had a very similar sound recently - seems it was most likely a burnt plug wire - but Im am glad I took it in -as they discovered a lifter was going ( which is what I feared from the sound) - so to hell with it - change everything
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
