07-04-2020, 02:24 AM | #1 |
Drives: FORD, FOCUS 2003 1.6 Join Date: Jul 2020
GLOWING RED EXHAUST MANIFOLDS?
Hi, all. Just had new exhaust manifolds, plugs, wires, distributor cap etc. put on my beast yesterday afternoon by the nearby shop. After warming it up this morning and starting to go, I get electrical snaps and popping noises very briefly, which immediately subsides and then the engine idles normally. Then I notice what feels like severe power loss climbing a steep hill, as if the engine is running out of breath. I return home and pop the hood only to find the manifolds glowing cherry red?? What is going on here? Thanks for any suggestions you guys may have.
07-04-2020, 11:24 AM | #2 |
Drives: '05 C6, '13 1LE, ‘17 2SS Join Date: Oct 2019
Easiest thing to check for is to see if the plugs were cracked due to over torquing on install (ask me how I know). Pull each plug and look at the white porcelain area closely under a good light source.
Also, this is in the classifieds area, you might want to post the same question in the correct area. |
07-04-2020, 11:29 AM | #3 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
Tags |
exhaust |
