10-01-2019, 07:36 AM | #1 |
Drives: 2016 Summit White Camaro LT2 RS Join Date: Jun 2016
AFM Valves
Whats the best way to temporarily keep these open all the time? I tuned out AFM months ago and wanted to see if there was any sound change with these kept opened. I don't want to have them cut out until I test the sound change if there is any.
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
10-01-2019, 09:47 AM | #2 |
Drives: 2001Camaro Z28 Join Date: May 2009
im going to follow this thread. very good question. I don't have the answer but I hope someone does.
10-01-2019, 02:19 PM | #3 |
Drives: 2017 camaro ss Join Date: May 2017
You can turn them off with HP tuners. I would think they would be open all the time with afm turned off anyway. Maybe not?
10-01-2019, 02:33 PM | #4 |
So I think you can do that on V8s. I should have specified I have a V6 which has simple mechanical valves that I believe operate on pressure.
10-02-2019, 09:10 AM | #5 |
Drives: 2018 Camaro 2SS, redline edition Join Date: Jun 2013
The best way to keep the AFM valves open all the time is the AFM range disabler device that plugs into your OBD2 port. The device does not reprogram the ECU. When you unplug it, there is no trace of it and everything goes back to normal.
https://rangetechnology.com/ |
10-02-2019, 06:49 PM | #6 | |
10-03-2019, 06:32 AM | #7 |
@caSSTro 18,
I know what you are saying and describing. In fact, all around it seems louder. If you want even more sound, pull fuse 51 to keep the NPP valves open all the time. |
10-03-2019, 07:04 PM | #8 |
My car is non-npp, but interestingly it still has a fuse in the F51 spot. I guess it’s just standard to put that in all Camaros to simplify the manufacturing process? Or that fuse is not for the NPP functionality but for the AFM valves? Idk
10-04-2019, 08:25 AM | #9 |
Drives: 2016 2SS Convertible Join Date: May 2012
If the AFM valve uses air pressure then it seems like the springs would have to be relatively soft. Maybe you can rig something temporary to mechanically hold the valve open for your test?
10-04-2019, 08:45 AM | #10 |
Yeah, they are really soft. You can push it in with your finger easily. I was actually thinking (don't laugh) duct tape. It wouldnt be on very long. Just wasnt sure if the tape would melt or not. I know people have done this before but the search function on the forums isnt the best...
10-04-2019, 09:22 AM | #11 | |
10-04-2019, 12:26 PM | #12 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
hose clamp.
10-04-2019, 12:48 PM | #13 |
Hose clamp might be the best because it needs to be a little wide so it doesn't slip off the top easily. Thanks for the ideas...
10-04-2019, 01:05 PM | #14 |
Drives: 17 Camaro 2SS 50th Anniversary Conv Join Date: May 2017
Pull fuse # 51 easy
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
Thread Tools | |
