Old 06-06-2018, 01:55 AM   #1
Larrio Andretti
Drives: Really Fast
Brake Fluid 101
The brake fluid you use is directly related to how your brakes will perform, but this fluid is often the most neglected maintenance item in a daily driven car. Neglect the maintenance of this fluid on the track and you will learn in a hurry how important it really is.
Brake fluid is simply hydraulic fluid…. An uncompressible fluid used to transmit force to the brake piston acting on the pad. Brake fluid is fragile. It’s hygroscopic which means it will absord water. If the brake fluid gets too hot it boils.The more water the brake fluid contains the lower the boiling point. If you boil the fluid you form bubbles of water vapor which are very compressible. The fluid no longer has the ability to transmit braking energy from the pedal to the caliper. The pedal goes soft and your ability to slow the car is compromised.
Air trapped in the line is also compressible and will cause a soft pedal all the time not just when hot.
In order to keep this from happening at the track you should at minimum bleed your brakes until the fluid runs clear. If your brake fluid is more than 6 months old it should be changed even if the car was never used. As it sits the fluid is absorbing water vapor from the air. How much? I don’t think anyone knows. But just to be safe it’s a good idea to use fresh fluid.
The type of fluid you use will ultimately be determined by your vehicle owners manual, but for the purpose of this article we will assume a modern car which operates on DOT type 3 fluid. DOT type 4 fluid is interchangeable with DOT 3. DOT 4 brake fluids have higher dry boiling points, but are unfortunately more hygroscopic than type 3 which is why it needs to be changed often. Don’t attempt a road course on DOT 3 fluid. It just won’t perform well.
Popular fluids for track days are ATE Super Blue which is relatively cheap at about $12 per liter. It’s dry boiling point is 536F, and it’s wet boiling point is 392F. MOTUL RBF600 is the next step up and is $20 per ½ liter. The dry boiling point is 593F, and the wet is 420. So even when it’s completely saturated it’s got a higher boiling point than the ATE Super Blue.
The ultimate in brake fluids are ester based. These include Castrol SRF, Endless RF650, AP Racing 600 and Brembo LFC600. Endless RF650, Brembo and Castrol are used exclusively in Formula 1 & Porsche GT3Cup cars. 1 liter of these brake fluids costs about $60-$80. Yeah… you read that right.
Boiling Points dry/wet in farenheit:
Brembo LCF 600: 600/399
Endless RF 650: 622/424
Castrol SRF: 590/518
Motul 660: 617/400
Wet boiling point on the Castrol SRF is impressive and significantly better than all others. You can see that Castrol didn't lose much performance between dry and wet. If you want the ultimate these are your choices but overkill for anyone reading this post.
I stick with the MOTUL RBF600 and bleed 1 liter through all 4 calipers before each track day. I have never had a problem with fade. The most epensive brake fluids come at a premium price and are in the realm of diminishing returns for money spent. They are better on paper but do you really need it.
Choose the most suitable fluid for your budget and brake deep and hard with confidence at you next track day!
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 06-06-2018, 07:25 AM   #2
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Thank you for this great info!
Retro69 is offline   Reply With Quote
Old 06-06-2018, 07:29 AM   #3
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Good info.
I will add synthetic brake fluid is available and it is not hygroscopic.
JB'sZL1 is offline   Reply With Quote
Old 06-06-2018, 07:47 AM   #4
Badgerbimmer
Badgerbimmer's Avatar
Drives: ZL1 A10
Castrol SRF period
My rides:
2017 Camaro ZL1 A10
2015 Jeep Grand Cherokee Diesel
2012 Audi S4
1992 Porsche America Roadster
1990 BMW 325Ic
Badgerbimmer is offline   Reply With Quote
Old 06-06-2018, 01:30 PM   #5
Larrio Andretti
Drives: Really Fast
Originally Posted by JB'sZL1 View Post
Good info.
Are you referring to DOT 5? That has no application for our Camaro so I didn’t mention it. It’s silicone based and not compatible.
THIS SPACE FOR RENT
Old 06-06-2018, 01:57 PM   #6
JB'sZL1
DOT3 synthetic is also available. I mention it because you mentioned hygroscopicity...and that brake fluid ought to be changed every six months. I'm not referencing it for track use, even though there is a high temp fluid.
Old 06-06-2018, 02:04 PM   #7
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Hold up. You use 4L to bleed before each track day????? Or 1 divided up by all 4 corners? If 4.....that’s a fawkton or fluid and way more than anyone I know that races.
ninetres is offline   Reply With Quote
Old 06-06-2018, 02:36 PM   #8
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Always used in all my cars RBF600 and worked flawless, changed every year.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 06-06-2018, 03:25 PM   #9
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Motul 660 here
Crash76 is offline   Reply With Quote
Old 06-06-2018, 04:29 PM   #10
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
...but for the purpose of this article ...
Since you didn't write it, how about sharing the source?
Old 06-06-2018, 05:51 PM   #11
Larrio Andretti
Drives: Really Fast
I wrote it. I have a blog for my race car. Thought I’d post it here to be helpful. Credit is to me. You shouldnt make assumtions in an accusatory manner.
THIS SPACE FOR RENT
Old 06-06-2018, 06:30 PM   #12
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i used motul 600 and used wilwood 550 in my old car lol good stuff way better than oem
Old 06-06-2018, 08:37 PM   #13
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Motul 600 is excellent and has never let me down! I have 2000 miles at VIR in my ZL1!
