01-25-2015, 05:36 PM | #15 |
01-25-2015, 06:01 PM | #16 |
tell you bud,,,vitesse #9 setting,.and you'll burn'em to the rims..
01-25-2015, 06:04 PM | #17 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I can roast mine no problem,TC off press the brake pedal and and feather the throttle in.
I did one beside another one I did with my 99TA and I got about 120ft out of both.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
01-25-2015, 06:08 PM | #18 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Could be in low octane mode from bad gas. Mine was like that at first when new until I did a fuse pull with some torco octane booster. If TC light comes on from shutting it off the car should have no problem spinning them. It shouldn't even need both stability and traction control to be turned off. It should spin them with ease with just the TC button hit once. Well, unless you have MT ET street drag radials on or something.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
01-25-2015, 06:10 PM | #19 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
91+ octane + fuse pull time.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
01-25-2015, 06:21 PM | #20 |
Drives: Camaro Join Date: Mar 2013
Take your left foot off the brake pedal.
01-25-2015, 07:16 PM | #21 |
Drives: 2013 2SS/RS A6 Join Date: Sep 2014
What is the difference between Competive mode and everything off on a L99 car?
01-25-2015, 08:29 PM | #22 |
Drives: 2016 2 SS Join Date: Jun 2014
Thanks for all the replies he has a tuner and has it running 91 octane tune traction control off and held down again still won't do a burn out for some reason just it doesn't seem to be hurting the 1/4 mile times just some times its good to be able to clean off the tires on the track.
69 Camaro
461 BBC street car 2020 ZL1 . |
01-25-2015, 09:09 PM | #23 | |
Drives: too many to say! Join Date: Nov 2010
01-26-2015, 07:22 AM | #24 |
Well we have been drag racing for years now and are pretty certain we can do burn outs he wet the road the other day and it wouldn't spin got to be omething with the traction control enough though its showing that its off not drag radials just the stock tires.
69 Camaro
01-26-2015, 09:09 AM | #25 |
Drives: '13 Hot Wheels SS Join Date: Aug 2012
I think you got a dud bro
01-26-2015, 12:57 PM | #26 |
Appreciate that Bro his car runs 13.20's as is bone stock other then a Diablo I-1000 seems pretty good was just asking if this had come up before not looking for arguments or SA comments appreciate everyones input going to look into it some more.
69 Camaro
01-26-2015, 07:13 PM | #27 | |
01-27-2015, 06:58 AM | #28 |
Not sure i can check
69 Camaro
