01-24-2015, 05:56 PM | #1 |
Drives: 2016 2 SS Join Date: Jun 2014
2012 SS L99 won't do a burnout
Title says it all my buddy's car is bone stock SS other then a I - 1000 tuner car runs 13.20's in 1/4 no cel's but car will not do a burn out even with the road wet any idea's and yes traction control is off.
Thanks for input in advance
69 Camaro
461 BBC street car 2020 ZL1 . |
01-24-2015, 08:37 PM | #2 |
Drives: 2014 2SS 1LE Join Date: Sep 2013
Is he holding the traction control button down for 5-7 seconds? If you turn stability so off (one click) or put it in competitive mode (2clicks) it won't let them spin...
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
01-24-2015, 08:39 PM | #3 |
Found a chart... This is for a M6 car 13 or newer so the steering response and launch control doesn't apply to his car but the traction control settings are the same.
01-24-2015, 08:58 PM | #4 |
Thanks i will check tomorrow i know i looked in threw thd window and saw the tc off for sure, maybe he just pushed the button twice.
69 Camaro
01-24-2015, 09:06 PM | #5 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
With just the traction control off it should be able to spin them. If he's unfamiliar with how the car will react he might want to leave stabilitrac on, it won't make any difference until it gets bent out of shape.
01-24-2015, 09:49 PM | #6 |
Interesting, I had no idea that our vehicle came with launch control. Does anyone have experience with this driving the LS3? How does it work exactly?
01-24-2015, 10:00 PM | #7 |
Drives: 2010 2SS/RS L99 SLP Cosmetics Join Date: Sep 2014
In addition to the other recommendations, put the shifter in M, and don't use the paddle shifters. This will allow the trans to start n 1st, instead of 2nd (really deep 1st gear). Smoke from the rear tires will follow!
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune. Now 12.93 @ 109.13. |
01-24-2015, 10:07 PM | #8 |
Drives: '13 Hot Wheels SS Join Date: Aug 2012
What is the difference between competitive mode and Everything off? Same icons for both, and i don't feel any difference driving it.
01-24-2015, 10:07 PM | #9 | |
I've never used it but to my understanding you put it in competitive mode push the clutch in floor it and it will keep the revs around 4K then drop the clutch... From what I've resd you can get more constant launches without it... Also heard of people breaking things with it
01-25-2015, 07:38 AM | #10 |
Going to try it today headed to the track for test and tune.
69 Camaro
01-25-2015, 08:32 AM | #11 |
Drives: 2012 2SS Convertible Join Date: Sep 2014
The Launch Control option is pretty cool. I've tried it a couple of times now. Send me a pm for the vid.
01-25-2015, 10:32 AM | #12 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Ported TB helps the L99 cars spin em over.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
01-25-2015, 12:12 PM | #13 |
Drives: SSICKO Join Date: Jul 2010
It needs more power!
Slowhawk Performance Built & Tuned
01-25-2015, 02:34 PM | #14 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Doesn't sound right...
Yesterday afternoon I turned off TC and SC (held button down for 8+ sec.) and stomped on it. Lit 'em up with no problem!
