Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 12-22-2013, 01:11 PM   #1
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Parking brake adjustment
I have read several threads that say you can adjust the parking brake by engaging it while backing up. This is not correct, at least on my 2012 SS w/ Brembo's.
The parking brake is a small drum brake similar to the previous 4th gen F-body's located on the backside of the rear rotors and is adjusted with a small star wheel after the rotors and calipers are removed.
'Back in the day' drum brakes had a ratcheting assembly that would hit the star wheel and lengthen the spacer screws that were then on the bottom of the shoes to tighten up the adjustment. There is no such mechanism on our rear parking brake. It is manual adjustment only. (I had to adjust mine when installing the R1 Concepts rotors today).
To make the adjustment tighter you turn the notches of the star toward the top of the assembly (See 8 in figure), to loosen, rotate it down. If it's too tight you will not be able to get the rotor back on so back it off a few notches at a time just until the rotor will go back on and not drag.
Hope this helps a bit.
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 05-06-2018, 10:17 PM   #2
HotRodV6
SyTy Speed Shop
Drives: 93 S10 LT1/T56 06 Tiburon GT
I know this is an old thread, but ive been searching forums and gm sites and google and i am looking for a part number for #5 in the above diagram, can anyone help with that?
Thanks
1992 GMC Sonoma GT
#003 of 806 Built
Procharged/Built 4.3 V6
02 Blazer ZR2
LSA 6.0/AWD T56
Under Construction
98 Olds Bravada
Lowered on Gen5 19's
5.3LS swapped DD
HotRodV6 is offline   Reply With Quote
Old 05-06-2018, 10:47 PM   #3
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I'm not real familiar with these cars but maybe check for the parking brake hardware kit?
chuckie669 is offline   Reply With Quote
Old 08-25-2018, 01:44 PM   #4
soylent13
CanuckCam2011
Drives: 2011 Cyber Gray 1LT Camaro
took me awhile to find them for myself
you probably have the parts by now but the part numbers are
92234840 and 92234841
mine was rusted up completely.
soylent13 is offline   Reply With Quote
Old 01-06-2019, 10:00 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
https://youtu.be/bB0WgCdRAM8
camguynj is online now   Reply With Quote
