Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 07-10-2015, 03:00 PM   #1
HurstPerformance
HurstPerformance's Avatar
Drives: 2013 Camaro SS and 2016 Camaro SS
Hurst Roll Control Kits for 2010-2015 Camaro
Hurst Part #5671518
Application:
Fits 2010-2015 Chevrolet Camaro
Description:
Designed with simplicity and ease-of-install in mind, Hurst’s complete Roll Control kits use the absolute best quality, pre-bent, double-walled, stainless steel brake line(s). In many cases, these hard-lines are superior to OEM quality. Hurst engineers realized when developing these kits that less is really more. Fewer connection points means fewer places where the system can leak and shorter lines mean less time bleeding the system. These kits are direct bolt-in meaning no measuring, no cutting, and no pre-bending; just simple, clean, factory-looking installs right out of the box. With easy, step-by-step instructions, you’ll be blessing the world with thick smoky burnouts and launching like a pro in no time.
Used primarily in drag racing to provide positive locking action to the front wheels of racecars, reducing the chance of “Rolling the Lights” and producing more effective burnouts for heating up the tires. Rigorous testing has proved a 1/100,000 of a second release time and vibration tests have seen up to 30 Gs applied without mechanical failure. Adaptable to most domestic and import hydraulic brake systems. CAUTION: Hurst Roll Control should not be used as an emergency brake, or any application requiring the solenoid to be activated for a long period of time.
Features and Benefits:
-Advanced stainless steel valve assembly for ultimate corrosion resistance
-Field-serviceable for cleaning or rebuilding to original factory specifications
-Fully-enclosed epoxy-molded electrical coil for reliability
-Attractive, finned-aluminum housing helps dissipate heat
-Wider, lightweight base provides better mounting stability
-150-micron screen filtered ports to prevent contamination
-Extra threaded port for separate bleeder or brake line pressure gauge
For additional questions, please call our Tech Line at 707-544-4761.
Last edited by HurstPerformance; 12-11-2015 at 03:10 PM. Reason: Updated Fitment Info for 2010-2015 Models
HurstPerformance is offline
Old 08-10-2015, 08:48 AM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Looking into this setup very soon.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline
Old 08-10-2015, 06:25 PM   #3
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
Is there is a kit for 13-15 Camaros?
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline
Old 08-11-2015, 10:27 AM   #4
HurstPerformance
If you have any question, give us a call at 707-544-4761.
We have fit-up Hurst part #5671518 onto our 2013 Camaro SS, but we have yet to fully test it. Most likely these kits will fit all the way through 2015 but we need to complete testing and evaluation to be absolutely certain. This should happen over the next few weeks.
Old 08-12-2015, 09:27 PM   #5
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Worked fine on my 13 Vert. Install was easy bleeding lines was hardest part.
Works great and doesn't throw any codes at all.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline
Old 08-18-2015, 11:39 AM   #6
HurstPerformance
Thanks for the feedback!
Old 08-20-2015, 02:15 PM   #7
smokum
smokum's Avatar
Drives: 2010 2ssrs
It would be cool if you could use one on the brakes, one on the clutch and a two step. That would launch an m6 real good.
smokum is offline
Old 08-20-2015, 10:33 PM   #8
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I have my two step hooked to the arming switch of the line lock along with a pedal position switch on the clutch. Works great.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline
Old 09-30-2015, 05:29 PM   #9
HurstPerformance
Sounds like a nice setup!
Old 10-04-2015, 09:17 PM   #10
RockRacer
RockRacer's Avatar
Drives: 2010 SS A6 Vortech, 3200 Stall 3.73
Love this kit. Agreed, bleeding the brakes was the hardest part. the arming switch fits nicely in the cigarette lighter hole (and take power from). Bought a shift knob from CFD that has the momentary in it. Very stealth, no extra holes. I have a reputation for doing John Force style burn outs now.
RockRacer is offline
Old 10-07-2015, 05:57 PM   #11
HurstPerformance
Happy to hear that.
Old 12-11-2015, 03:08 PM   #12
HurstPerformance
We have confirmed that the existing Hurst Roll Control kit for the 2010+ Camaro, part #5671518 will carry on through the 2015 model year for the same sub-model configurations as previously listed.
Old 12-11-2015, 11:16 PM   #13
j.curt
Drives: 2017 Camaro 1SS
Will this work with the WOT Box? http://n2mb.com/wotbox
j.curt is offline
Old 12-14-2015, 04:35 PM   #14
Tech@HurstPerformance
Tech@HurstPerformance's Avatar
Drives: 2016 Camaro SS
We have not tested our Roll Control for compatibility with any other aftermarket systems.
Tech@HurstPerformance is offline
burnout, drag racing, hurst, launch, roll control
