04-06-2018, 05:55 PM | #1 |
Drives: FIFTY 2SS Callaway Join Date: Sep 2017
Rear ZL1 brake calipers and rotors are a bigger than SS
I have been working on switching out my stock SS brakes for the ZL1 brakes. I just realized the rear rotors and calipers for the ZL1 are bigger than the ones on SS. The rotor part numbers are different between the two and the calipers are a little different between the two as well. Most believe that the rear brakes and rotors are the same. I will post the parts numbers of each as I continue to do the swap.
04-06-2018, 06:55 PM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
While you are changing do you mind sharing later all the necessary part # please.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
