09-04-2019, 05:48 PM | #1 |
caliper bolts ZL1 VS SS part numbers neded
anyone know if the ZL1 has different caliper bolts front and rear then the SS? Wonder why the online parts diagrams dont list the caliper bolts if they are one time use.
09-04-2019, 10:34 PM | #2 |
By no means is this a parts diagram but a quick search of Rock Auto doesn’t call out different parts numbers from the SS to the ZL1.
Also there’s no call out for either trim indicating different major diameter, pitch or length differences. Nor is there a deviation from front to back. It’s calling out an M14 x 2.0 x 63mm long bolt. If you have a pair of calipers you can check the minor diameter of the threaded hole in the caliper to see if it measures 12.0 mm. (+0/-0.15mm depending on % of thread) Take it with a grain of salt, but my curiosity made me want to research your question. Side note: Major Diameter - pitch = minor diameter. This works for metric or imperial threads and is to be used as a reference. Machinist handbook is more precise but this gets you in the ballpark. (************************************************) (Disclaimer: (lol) This is a reference and not an ANSI, ISO, JIS, etc. standard) (************************************************) Example—>M14 x 2 is 14mm -2 (subtract pitch) = 12mm minor diameter 1/2”- 20 is 0.500” - 0.05” (1/20=0.05” decimal equivalent to pitch) = 0.450” minor diameter (29/64 is 0.453” and is common call out) ZL1 https://www.rockauto.com/en/catalog/...ing+bolt,13055 SS https://www.rockauto.com/en/catalog/...ing+bolt,13055 Carlson H818 information https://www.carlsonqualitybrakeparts...Flyer-2018.pdf
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ Last edited by Trochoidal; 09-04-2019 at 10:43 PM. Reason: Added disclaimer |
09-04-2019, 10:43 PM | #3 |
ya those are aftermarket for the front. im looking for factory part numbers for front and rear. i dont trust aftermarket. the old SS bolts do thread into the ZL1 calipers. but at around 130lb ft on aluminum it has to be correct.
09-04-2019, 10:47 PM | #4 |
Good to know for future reference. I should’ve known it was too good to be true. Also, I don’t blame you at all for the not trusting aftermarket.
09-04-2019, 10:55 PM | #5 |
those are correct for the fronts 13.76mm (M14 x2.00) x 2" but rears are 11.73mm (m12 x 1.75) x 1.68"
09-04-2019, 11:03 PM | #6 |
lol the track deflector instructions say to reuse the caliper bolts at tq to 148lbft
09-04-2019, 11:09 PM | #7 | |
Are the bolts from your stock brakes stamped with 10.8 or 12.9 on the head?
09-04-2019, 11:30 PM | #8 |
10.8 s grade 8
09-05-2019, 11:45 AM | #9 |
just ordered the factory bolts at my dealer. ill post the part numbers when i get them tomorrow. Ill also do a sticky on TTY bolts and there replacement numbers.
09-05-2019, 01:05 PM | #10 |
Good work. Well now you’ll have exactly what you need.
Thread Tools | |
