Old 06-14-2023, 01:56 PM   #15
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Originally Posted by NYJets12 View Post
Here’s how it’s done it’s in the forum somewhere. I took a picture of it for myself.
Well that is not using your infotainment OnStar WiFi to connect other devices via WiFi to your "infotainment/autos HotSpot". That is how to setup your iPhone as a HotSpot in order to connect your infotainment to your iPhone via your iPhone's HotSpot. I know things like your wireless android auto connect to your infotainment via WiFi... If I'm not mistaken.. but I've never tried to set that up.
Completely Different. We are not talking about doing the same thing
Maybe I misunderstood what the OP was asking.
jamala00 is offline   Reply With Quote
Old 06-14-2023, 09:36 PM   #16
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
I was asking about the Wi-Fi settings that connects your car to a Wi-Fi network. I'm not asking about the hot spot settings. They are two different setting selections.
When I get a chance I'll do a reset by disconnecting the battery.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is online now   Reply With Quote
Old 06-15-2023, 02:26 PM   #17
jcharm
Drives: 2021 LT1 Camaro
I get it now. It should be simple. Here's what he's trying to do.
https://youtu.be/W4g7xpJCPvg
jcharm is offline   Reply With Quote
Old 06-15-2023, 07:40 PM   #18
SS_Don
SS_Don's Avatar
Exactly.
Old 06-18-2023, 02:38 PM   #19
SS_Don
SS_Don's Avatar
I tried the battery reset and also the reset procedure that was posted and neither worked. In fact the reset procedure did nothing. I then called OnStar and they couldn’t solve it either. I guess it’s off to the dealership.
Old 06-18-2023, 06:52 PM   #20
Interesting that OnStar couldn't resolve it either.
I went through the service manual for my 2018 and wifi is discussed exclusively in the context of OnStar, both in terms of hardware and software, and my car has the same dual wifi functionality (connect to external wifi network + hotspot). Thus I would've guessed your OnStar subscription expired and they eagerly turned off your entire wifi functionality, but if you already called them, it may be something else.
Old 06-19-2023, 02:59 PM   #21
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I decided to check my wifi the other evening after I got home from work. Once I got into the garage, it took a minute for my home wifi to come up (it showed nearby networks before my own). When I tried to connect, it failed the first time, but then connected. I checked for updates just to make sure it was working (no updates available).
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint
RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit
My Camaro Journal
Old 06-19-2023, 03:11 PM   #22
SS_Don
SS_Don's Avatar
Do you have an OnStar subscription? If so, what level?
Old 06-19-2023, 04:49 PM   #23
DamonZ28
DamonZ28's Avatar
No, I do not. The trial subscription I had expired in February. Sorry, I meant to mention that.
My Camaro Journal
Old 06-19-2023, 05:55 PM   #24
SS_Don
SS_Don's Avatar
I was hoping you were going to say that.
Old 07-12-2023, 03:20 PM   #25
SS_Don
SS_Don's Avatar
Sorry for the delayed response. I finally fixed it. I had performed my searches for this issue on the web. Nothing came up. So i took my car to the dealership and after having the car all day they called me to tell me that they can't find anything wrong. Said they called on-star and they were telling them that I need a data subscription for it to work. I told them you don't and that it used to work. Asked if they could keep the car another day. I said sure.
The next day I searched the web again. This time I widened my search by not including Camaro. One hit came up in a Traverse forum and they had the solution. It turns out there is a setting in the mobile app for wi-fi hotspot. If you disable it, which mine was, it also disables the wi-fi network. No where is this documented. I enabled it and 15 minutes later I get a call from the shop saying it is working.
Old 07-12-2023, 04:35 PM   #26
jamala00
jamala00's Avatar
So a setting in your My Chevy App caused the setting in your infotainment unit to not be enabled... Nice find... Glad you figured it out.
Old 07-12-2023, 06:53 PM   #27
SS_Don
SS_Don's Avatar
Luckily someone in a Traverse had the same issue and reported it and the solution. It was the only reference to the problem I found.
Old 07-12-2023, 07:29 PM   #28
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
that's....ridiculous. thanks for letting us know!
Anjilslaire is offline   Reply With Quote
