Old 01-17-2021, 02:28 PM   #1
bcasurvey1
Drives: 2019 White ZLE
i have thumping, rattling, knock noise in front end any one else?
so i just started hearing a noise when i go over speed bumps or any bump / pot hole. it sounds like a loose shock or something rattling in front end, but only when i hit a bumop, i looked around under it and couldnt find anything loose, has this happened to any one else and how did you fix it? 2019 ZLE thx
bcasurvey1 is offline   Reply With Quote
Old 01-17-2021, 08:57 PM   #2
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1(FEA suspension) Rapid Blue
Probably a defective DSSV strut. Seems to be quite a few failures reported on the forums recently.
Crushed 1LE is offline   Reply With Quote
Old 01-18-2021, 05:49 AM   #3
CasualGuy
Drives: '19 ZL1 1LE | ‘19 MX-5 Miata 30AE
Agreed. I just had my RF strut replaced under warranty for the same issue with 18 months and ~12,000 miles on the car.
CasualGuy is offline   Reply With Quote
Old 01-18-2021, 05:54 AM   #4
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Could be. Just had mine replaced. 9K track miles.
breakskeet is offline   Reply With Quote
Old 01-18-2021, 08:22 AM   #5
Snakebt6
Drives: Rally Green 2020 ZL1 1LE A10
I had a bolt work itself loose from inside my right front damper actually. 2020 with 3k miles. After the break in miles mines been mostly a track car.
It made a clunking pretty ugly sound over bumps..I would get it checked out before driving it any more.
The damper was replaced under warranty and the faulty one sent back to the manufacturer.
Snakebt6 is offline   Reply With Quote
Old 01-28-2021, 09:15 PM   #6
bcasurvey1
wow thanks for the help, i guess i need to take it in for service.
Old 01-31-2021, 12:00 AM   #7
Synister87
Drives: 2018 ZL1 1LE
Mine was brand new. The mechanic said it it didn't even look like it had been bolted together. Oddly enough it was the right front too.
Synister87 is offline   Reply With Quote
Old 01-31-2021, 07:10 AM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I've also seen the aluminum X brace that shops remove to do headers get loose or bolted back touching parts and making the same noise.
EDFHOBBIES is online now   Reply With Quote
Old 01-31-2021, 07:10 AM   #9
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
GM has got to get their QC department on the job. This is the kind of thing that can kill a business. People...........
Bangkok_ZL1 is offline   Reply With Quote
