06-14-2017, 03:49 PM | #1 |
Drives: White 2011 RS with black stripes Join Date: Jan 2017
Trunk seal
Not sure if this is the right place, sorry if it isn't I'm new. I have a 2011 rs that has a series of lacerations in the trunk seal/gasket, causing it to leak a bit. Anyone have any suggestions what to do, or had this happened? Thanks!
06-14-2017, 03:52 PM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Literally had a trunk water leak which eventually flooded the battery compartment... while my issues was more than lacerations, just be careful because the battery is in the trunk.
My total bill to fix trunk and battery came out to $600 at the dealer :(
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
06-14-2017, 03:52 PM | #3 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
my 2014 just pulls right off. seems easy enough to replace.
06-14-2017, 03:54 PM | #4 |
I already had something similar happen! It was about 2 inches of water in the trunk. I took everything out, including battery and spent 2 days drying it. We have a lot of rain here in the south. While it has not been as bad there still is water getting in. Even after a wash.
06-14-2017, 03:57 PM | #5 | |
I like teeth.
06-14-2017, 06:25 PM | #6 | |
the weather striping is only $67.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
06-14-2017, 06:54 PM | #7 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
So there are lacerations in the weather stripping and you are looking for suggestions? You could duct tape over the gaps around the trunk, not drive in the rain, drill holes in the trunk floor to drain the water, or REPLACE THE DAMAGED WEATHER STRIPPING.......take your pick.
06-14-2017, 07:37 PM | #8 |
Drives: 2013 1SS L99 Join Date: Dec 2015
If you have a sunroof check the drain tubes. They become disconnected easily.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with Borla Touring exhaust - ESS Tuning YSI V7 - Fore Innovations Dual pump fuel system - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - Yank 3400 Stall -
06-14-2017, 09:08 PM | #9 |
Drives: Camaro Join Date: Mar 2013
Your car is ruined, sell it.
06-14-2017, 09:14 PM | #10 |
Drives: Miss Con Ception Join Date: Aug 2016
You should be treating all your weatherstrips twice a year to prevent them from drying out. I use Griot's vinyl and rubber treatment but there are a number of other products that work well.
You should also treat the plastic pieces such as your grills, lights, rear diffuser, the tail light covers, dashboard and shelf package, etc.
2011 1SS/RS LS3 CGM
06-14-2017, 09:31 PM | #11 |
Drives: '10 2SS Inferno Join Date: May 2017
Kajun, no trunk problems here but I do have a sunroof. Where do I check for disconnected drain tubes? Are they visible from above an open roof? I've never looked for those in any previous vehicles I've owned that had a sunroof.
06-14-2017, 09:35 PM | #12 | |
06-15-2017, 07:13 AM | #13 |
Drives: 2014 2SS/RS Join Date: Dec 2014
Some folks reported that the trunk lid wiring cable chafes on the weatherstrip and they needed to adjust that.
Is the damage in the area near the lid cable or is it near the bumper side where packages are loaded in to the trunk?
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
06-15-2017, 07:29 AM | #14 |
My drain tubes disconnected on their own and I got some moisture in my trunk. They typically disconnect in the trunk. If you open the lid and stick your head in there, you will see a tube on each side that slides into a boot that dumps right outside the frame. I used silicone to seal the tubes and the leaks stopped.
