06-02-2014, 10:43 PM | #43 | |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
06-09-2014, 07:53 PM | #44 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
But the Camaro should be on the smaller lighter short wheel base ATS chassis not the long wheelbase heavier CTS version. If the Camaro doesn't drop 250 to 300 lbs there in trouble. BTW, the 2015 mustang is said to be 200 lbs heavier, mustang lost no weight and that's great news
06-09-2014, 10:50 PM | #45 | |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
The ultra torquey LT1 Corvette equipped with the 7 speed manual has a rear end ratio of 2.56 and a 7th gear ratio of .42. Very, very low engine speed. I am quite interested in seeing what the ratios on the 8 speed Z06 are. (Note: C7 has a CD of .29. The 2014 CTS has a CD of .29 from what I've found. V6 Camaro has a CD of .36, but the 2LS can still achieve 30mpg highway. Things to consider.)
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
06-10-2014, 08:49 AM | #46 |
Drives: 2014 2SS/RS Convertible Join Date: Jun 2013
If we are estimating the weight loss just relative to the platform changes that the OP referenced, I think the Camaro will lose 300-400 pounds. You have to remember the new CTS which moved to the long wheel base alpha platform is actually bigger (at least in most dimensions) than the sigma platform CTS and it still lost weight. I could be wrong, but I suspect the next Camaro will be quite a bit smaller and based on the short wheelbase alpha. If that is true, weight loss of 300 - 400 should be very acheivable.
As far as content goes, comparing a mid line Cadiallac to a Chevy Camaro is crazy. But I would estimate that the level of content creep from the old CTS to the new CTS could be roughly comparable to the content creep on the 5th gen Camaro to the 6th gen. I will definitely be disappointed if the 6th gen doesn't lose at least 300 lbs. |
06-17-2014, 03:12 PM | #47 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
From Entertainment Weekly, in an interview with Micheal Bay: http://insidemovies.ew.com/2014/05/2...hael-bay-cars/
Quote from article: Quote:
2010 Camaro 1LT V6 (Sold. I will miss her!) |
06-17-2014, 04:11 PM | #48 |
Track > 1/4 Mile
Interesting..
06-17-2014, 10:23 PM | #49 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
06-18-2014, 12:02 AM | #50 |
Drives: 2020 LT1 Black Join Date: May 2013
I think it's funny that Ford still hasn't revealed the weight and power of the new Mustang even though it's right around the corner. It's like every minute they hold back that information is critical in the Camaro vs. Mustang competition.
06-18-2014, 12:43 PM | #51 | |
So chevy really should be gunning for a weight target, which is to weigh basically the same, or less than the Mustang. With the LT1, and a similar weight, the GT would have to make a lot more HP to be much faster in a straight line. Alpha is already deemed a superbly handling chassis, so that shouldn't be an issue either.
06-18-2014, 12:56 PM | #52 |
I'm thinking Ford isn't happy about the final weight and power numbers so they are waiting as close to the release date as possible so people don't cancel their preorders.
06-18-2014, 12:57 PM | #53 | |
06-18-2014, 03:56 PM | #54 |
Drives: some to distraction Join Date: Sep 2011
They are counting on RAVE reviews at the long-lead press event from worldwide journalists: how much better it rides and handles than the obsolete stick-axled current ones, how strong the driveline and added power feels...oh, and they better get the vast majority of '14s sold, so they don't get saddled with mega-rebates$ to move such piles...
06-18-2014, 05:35 PM | #55 | |
Granted that's a different competitive situation. The Vette is in a class by itself and the Viper barely has a pulse. The Mustang vs. Camaro rivalry is almost religious. Maybe moreso. In spite of all the bad news around GM, I think they easily have the best performance division in the US and the next Camaro is going to be a total gamechanger in the muscle car segment. They just have to get the styling right... |
06-19-2014, 09:35 AM | #56 | |
Drives: 2012 Camaro 2SS Join Date: Feb 2012
The transmission and rear end ratios in the Mustang make much better use of the power it has available. Take a look at the actual torque per gear chart for both cars now. All in all I don't see the weight reduction many of you are hoping for coming to fruition. The Mustang crowd thought it'd happen with the 2015 and it ended up weighing more. Each has to update for new safety requirements and that adds up quickly. In the end the new Camaro will most likely end up weighing the same but sport added power. |
