07-26-2020, 10:06 AM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Zl1 square setups
So im looking to change out my wheels and tires. I would like to run a square setup because I think it would be better for the track. I will start going to the track soon and I drive hard in the street. I was thinking Apex Arc-8 19"x11" front and rear. And running a 305/30-19 or 315/30-19.
Not sure what tire are guys running for hard street rides and track use. Also is anyone running a square setup? Does it mess with the handling and feel? Also thinking installing Vorshlag camber plates to help with camber adjustments. Any feedback and suggestions appreciated. |
07-26-2020, 12:25 PM | #2 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
Have you done some track days with your current setup?
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle |
07-26-2020, 01:46 PM | #3 |
07-26-2020, 02:37 PM | #4 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Do you have any track time yet? I did just fine for several years only going once or twice a year on my OEM 17 Camaro SS. If you have a bunch of track time, you probably know what you want. If you don't, I would wait until you get some instructed seat time.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
07-26-2020, 10:24 PM | #5 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I did the bronze ARC-8's 19x10 square running Michelin Pilot Sport A/S 3+ 285/35-19's and have kept my stock set for when I want to track it or find some winding roads.
07-27-2020, 06:37 AM | #6 |
07-27-2020, 07:07 AM | #7 |
07-27-2020, 11:19 AM | #8 | |
I track my car when ever I get a chance and it's completely stock other than the "track alignment" and I feel that the car is definitely not holding me back, but I'm holding the car back. I typically run in the advanced group at our track events and run towards the mid/front of the pack, so I'm not babying the car. If you have years of tracking experience under your belt and can drive a car at it's limits, then maybe a set of dedicated wheels/tires would help. Now if you are wanting to get another set of wheels for looks alone, consider keeping the stock wheels/tires for your track setup and use the new ones for street driving with a more street/daily driver friendly tire.
07-27-2020, 01:26 PM | #9 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
07-27-2020, 02:17 PM | #10 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
- Performance in cool weather. It's basically a waste of time and money to go to an event if the tires won't heat up. Terminal understeer is not that much fun. - Running a more street oriented tire on the stock rims such as Michelin PS4S. If you drive the car on the street a lot this may be a good idea, then getting some dedicated 19s for track so you don't destroy the PS4S too quickly makes more sense. I don't care that much if I can get better results by spending $$$ on tires, I don't have goals that include high level competition. My main issue is if temps are too cold and I have to run early the stock tires never get warm enough for autox, it really does make late season events almost not worth attending if it's colder out.
07-27-2020, 03:18 PM | #11 |
Ok so I don't have experience on the track with cars but I did track with motorcycles which is a different animal. The only reason i believed that changing out the stock wheels would benefit is weight reduction and also tires would be cheaper.
07-27-2020, 03:23 PM | #12 |
Also I dont drive in the cold weather or rain. And when I do go out for a ride its for the backroads and take it pretty hard.
Would I benefit from adding camber plates for better adjustability for camber? |
07-27-2020, 06:28 PM | #13 |
The stock suspension (production tolerances can vary) can be set to 2.3 - 2.6 degrees negative camber in the front, which is good enough for any aggressive street setup and most track setups. For this reason camber plates are not necessary for street or most track applications. Those that use their car primarily as a track car or track very often may find they need more negative camber than the stock suspension can provide, in my opinion for those that only track their cars a few times per year camber plates probably are not needed.
07-28-2020, 09:57 AM | #14 |
I did the square setup for daily driving and of course come winter time I don't have to worry about the tires warming up, the stock set does handle better when it comes to stance and softer tires because it grips better.
