06-15-2020, 09:25 PM | #1 |
Drives: 2021 LT1 6 SPEED MANUAL CAMARO Join Date: Jul 2019
gearing questions
is it possible to just buy a 3.27 ring and pinion kit to replace the oem 2.77 ring and pinion rather then buying the entire actual differential? i know i wont get the limited slip feature but i will atleast have the gearing which is what i want. is it possible to remove my ring and pinion and replace with the 3.27 or will it be cheaper to just buy the actual diff?
06-16-2020, 05:33 PM | #2 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
whatever you end up doing, the car's trans tuning is based on commanded torque I believe. Changing gear ratios is going to potentially throw how it shifts out of wack, on top of the speedo updates needed.
Doesn't sound like a fun diy job unless you do tuning as well. |
06-16-2020, 08:26 PM | #3 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
How much is a used T4 Camaro rear going for?
06-21-2020, 09:17 PM | #4 | |
06-21-2020, 09:17 PM | #5 |
