02-28-2015, 11:33 AM | #15 |
Drives: bicycle Join Date: Jun 2014
A nice charger and some real nice suspension with super sticky tires.... And be safe on the road
02-28-2015, 01:06 PM | #16 |
Drives: 416 w/TH400 Join Date: Mar 2012
if it was built for N/A you might not have enough ring gap for boost..... check with the builder
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
02-28-2015, 01:58 PM | #17 |
movin' down the motorway
Drives: Summiit White 2SS/RS/M6 Join Date: Feb 2010
Definitely. I'll get together with Matt at FSP and discuss best options as they did the N/A build.
417 stroker - Florida Speed and Power
02-28-2015, 11:29 PM | #18 | |
Drives: 2011 Camaro SS Join Date: Dec 2012
Hey bud.. I'll hit you back tomorrow been swamped.. Twins... yummy.. That motor will take some decent boost, with the high compression we will have to add some methanol OH WELL |
03-01-2015, 09:26 AM | #19 |
Drives: SS, CTS & SRT-4 Join Date: Aug 2009
This thread's heading is misleading.
I came here expecting 2 red-heads...
03-01-2015, 10:43 AM | #20 |
03-01-2015, 10:50 AM | #21 |
Drives: 2010 Camaro 1ss IOM Join Date: May 2009
One Red head!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now! |
03-01-2015, 10:52 AM | #22 |
Two Red Head!
03-01-2015, 10:53 AM | #23 |
Sounds like Matt will fix you up with all you need twins or a blower will put your car of the top good luck!
03-01-2015, 10:56 AM | #24 |
Boosted Moderator
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-01-2015, 12:42 PM | #25 |
Drives: 2011camaro SS Join Date: Nov 2012
You will need to change gears too! Twins don't need it!
03-01-2015, 12:51 PM | #26 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Do it! its awesome! I'm stock bottom, we stopped at 747 but the car had more in it. Your motor will do more providing you have the fuel.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
03-02-2015, 10:23 AM | #27 |
Drives: C7 Z51 Join Date: Mar 2014
check out our twin turbo kits that we offer for Camaros. We have 2 different kits that are good to ~750 rwhp and ~1200rwhp. all the best components, no cutting corners. we've been delivering quality components since 2010 for these cars and know them in and out. let us know if you have any questions.
http://www.fabberge.com/chevrolet/ca...urbo-kits.html |
