07-17-2019, 09:56 AM | #1 |
Drives: Nightfall Gray 17 ZL1 Join Date: Sep 2017
Diode Dynamics
Do not purchase the DIODE DYNAMICS RGBW LOWER DRL LED BOARDS that state they fit the 2016-2018 Camaro ZL1. The LED boards for the lowers do not fit and Diode Dynamics has confirmed this even thou that stated it did on the forum.
I now have to take apart the upper DRL again and pull out the LED boards as the DRL would not match between upper & lower..... Phastek is issuing the refund, but I'm still irate that I spent all the time to separate the headlights and install the boards, and then separated the lowers to find they don't fit. Thanks for letting me vent! |
07-17-2019, 04:25 PM | #2 |
Drives: ZL1 Join Date: Nov 2016
Thank you for the input as my set JUST came in the mail!
07-18-2019, 05:41 AM | #3 |
Update: Diode Dynamics sent email last night stating that they are working on new LED boards to fit 2016-2018 ZL1 Lower DRL. They will be ready towards end of August.
07-18-2019, 06:32 AM | #4 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
just went through a similar deal, but i can’t complain about their customer service one bit. it would be nice to have had a heads up about compatibility huh?!
if you ever have to change a low beam on an 18 grand Cherokee, i feel for you... |
07-18-2019, 10:19 AM | #5 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
Diode dynamics uses an RGBW board with a warmer white LED than OEM. You will find that it is both wrmer and dimmer than the normal running lights. So if anyone buys just the upper boards and runs the lower OEM LED's, it won't look good togeyther.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
07-18-2019, 12:44 PM | #6 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
I was wondering when they said it does both. The lights don't even look similar, so I was curious on how that works.
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
12-09-2019, 03:13 PM | #7 |
The Black Emerald
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS Join Date: Sep 2011
Any update on the lowers for the ZL1?
12-11-2019, 07:27 PM | #8 |
12-13-2019, 10:08 AM | #9 |
Drives: White 2015 Z/28 Join Date: Jul 2017
I'd just stay away from Diode Dynamics period. I've seen the Gen5 guys complain about their side markers and mail slot lights going out after only a few months. I really wanted a pair but the reviews were Meh at best so I stayed away.
OP, I'd be furious to have to pull the car apart that far, just to have to put it back together stock, then try again when they possibly get it right later, especially when they are 4 months late on the fix. Can't imagine it's that hard to make the correct set... Oh well. Happy Modding! |
03-10-2021, 08:48 AM | #10 |
Drives: 18hyperbluzl1/22C8 Join Date: May 2017
does the front bumper cover have to come off the zl1 in order to take out the headlights & drl's to install the diode dynamics package
03-10-2021, 10:25 AM | #11 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Update to the thread: They offer now the lower drls for the ZL1 also. Just installed mine.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
