07-16-2019, 04:54 PM | #15 |
Drives: 2017 Camaro SS Join Date: Mar 2018
Where's a good place to get the lt5 tb? Should it be ported?
07-16-2019, 06:13 PM | #16 |
Drives: 2017 1ss 1le Join Date: Sep 2015
You really need to find a good tuner and ask them for their advice in putting together a complete build.
07-16-2019, 06:44 PM | #17 |
07-16-2019, 06:57 PM | #18 |
Drives: 21 SS Join Date: Oct 2017
Imo send msd to pray to get ported. That would be worth more and cost same or less than adding a 95 or 103 tb on stock msd.
07-17-2019, 06:15 AM | #19 | |
As far as what the 95 does, check out Tick's test of unported MSD/unported 95 vs stock, and unported MSD vs stock, it has dyno charts for both https://www.camaro6.com/forums/showthread.php?t=535959 |
07-17-2019, 08:48 AM | #20 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Make sure you dont have any leaks.... I believe the foam must be removed.. it will leak...
Also, I had a ported oem and went to ported msd... honestly i hated the change because the car felt slower (mid range is very noticable. However, running to equally modded cars (but without the msd) you will see the difference AND its a must have if you plan on going heads/cam in the future. The little bit you gain on top end with the msd isnt that noteable unless you actually are at a drag strip or against another car you ran before.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
07-17-2019, 08:50 AM | #21 | |
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
Well............ At least you tried. lol
07-17-2019, 08:58 AM | #22 |
Msd says to leave the foam on when you call them 5/2019
To me sounded like car feels weaker which makes sense because you feel torque more than horsepower with your ass. If you actually measure the car you will see your ass is wrong and the car is indeed faster. Last edited by 6spdhyperblue; 07-17-2019 at 10:23 AM. |
07-17-2019, 09:41 AM | #23 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
07-17-2019, 10:25 AM | #24 |
So any info on what the porting on a msd is really worth over a msd/95(just cleaned up- flashing removed)
07-17-2019, 11:09 AM | #25 |
Drives: SS 6 speed of course Join Date: Jan 2016
It would be my opinion, that FBO, I'd go with a Pray ported setup, your option for stock ported TB or 95mm (ported or not).
If you are going headers and cam, then ported MSD, ported 95mm would be the way to go. The middle of road well I will go to heads and cam in the future... hmm, I probably do the Pray ported stuff and then sell.
07-18-2019, 12:31 AM | #26 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
You're running the msd on a stock tune without issues or a cel? I was under the impression the msd needed a tune unlike a ported stocker but I am probably wrong.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
07-18-2019, 02:07 PM | #27 | |
@Blackmamba_1LE
07-18-2019, 02:29 PM | #28 |
For about 6 months I ran CA front cat deletes, MSD, CAI and 103 TB, the only change to the program was taking off the monitors to the front 02s. Now it was much quicker after it was tuned by EFI Tuning, I'm just saying it ran fine with the stock tune minus the front 02 monitors.
