07-16-2019, 11:16 AM | #15 |
Drives: SS 6 speed of course Join Date: Jan 2016
remove Texas Speed and just note that any header in any car may need modification period. The bigger tube and cheaper header may have more issues. Pretend you don't know about it causee it makes NO HP difference... it is a piece of the exhaust system. The stock system has all 4 tubes going into a 2.25" hole.
07-16-2019, 11:59 AM | #16 | |
Drives: 2016 2SS Join Date: Apr 2018
07-16-2019, 02:08 PM | #17 |
Well all is good then, I'm glad they stood by their product; would not want a scratch in the coating robbing any HP..
07-17-2019, 08:23 AM | #18 |
Started#gottalovethatblue
It's a bummer to hear that you've had such difficulties with their headers. So many people have had such great luck with their headers, but there's always exceptions to the rule. Personally I went with Kooks because so far I've been putting American made parts on the car to support American jobs. Some people think it's just a waste of money and it's not going to make that big of a difference, but it's my choice and my ride.
Good luck with your headers. I hope the next set fit better. Don't condemn all of TSP's parts based on their headers. They make MANY very high quality parts with many people racing with great success with them.
07-17-2019, 08:30 AM | #19 |
My 1 and 7/8 Kooks have lots of room, about 3 stock spark plug wires need to be modded and or moved. I do remember the initial Kooks did have some fitment issues with the cross member brace. Once again I think Kooks is a quality header, but it is not unusual to run into fitment problems. Putting dents into headers have been done probably since headers have been invented. This causes no performance issues. How upset should one be about a cosmetic issue with an exhaust?
07-17-2019, 08:42 AM | #20 | |
07-17-2019, 08:45 AM | #21 | |
07-17-2019, 11:04 AM | #22 |
A nick in the coating equals minuscule temp change in the engine compartment. lets see 2" diameter tubes by 32" long gives me a surface area of: 824 square inches vs a massive crack say 1/4 wide and 1/2 long, heck lets say there are 3 of these crank the numbers .38 of square inch or about um .02 of the coating which may increase heat rejection say 5%. crank in a total delta change of heat rejection .001 that number . It is purely cosmetic and it is an exhaust. I'm not saying anything else. It is cosmetic, do you need want or should get a replacement that is between you and the vendor. I am merely saying it is cosmetic, yet you keep insisting there is a measurable performance difference.. there is not.
07-22-2019, 08:30 AM | #23 |
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
i just got done installing the headers and had no issues, with the install itself. it went pretty smooth finished it with a buddy within 6-7 hours. but my only question is i hear the bolt rubbing when i turn the steering wheel. im not sure if we put the bolt in the wrong hole of the steering shaft or what but there are 3 different holes there. does anyone know which one it is?
Well............ At least you tried. lol
07-22-2019, 08:34 AM | #24 |
It’s supposed to go in the hole near the rear two primaries. Some grind the the “nut” side too but not sure about that
07-22-2019, 08:53 AM | #25 |
so screw the bolt from the bottom end of the car or from the engine bay?
07-22-2019, 09:15 AM | #26 |
For the money savings they are worth every penny. We run into issues with the 2" every now and again with the steering shaft bolts hitting the header. They come with a lower profile bolt to help but sometimes there is still contact in extreme situations. Nothing a dimple can't cure.
07-22-2019, 09:43 AM | #27 | |
Drives: 2017 ZL1 6MT Join Date: Feb 2018
So I can imagine how you feel to have to dent your ceramic coated headers. That would most definitely rub me the wrong way.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
07-22-2019, 10:28 AM | #28 | |
Can I drive it even if the bolt is hitting it? Would it do anything to it? Sent from my iPhone using Tapatalk
