10-13-2018, 01:53 AM | #1 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Drop In Piston Install while motor is IN THE CAR
OK so I know I have some other threads on here but I am trying to make this one pretty specific to the actual installation of Drop In Pistons while the motor is in the car. I know it is possible...if you watch Lethal's videos, Cunningham did his while the motor was clearly in the car. Others have noted that Vengeance and other tuners have done this often as well.
However, when I go on Youtube, this forum or the Corvette forums, there is little information about the install. I am not near any of the shops of note for our platform but I have a very capable mechanic shop I have worked with for more than a year now. They asked me to send anything I could find on this work so we can set this all up. I have bought the following from Jannetty Racing:
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
10-13-2018, 07:01 AM | #2 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Total side note from all of this but, why the stock LS1 rods?
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
10-13-2018, 12:30 PM | #3 |
Didn’t buy rods that is just the description for the rod bolts. It was probably them just cut and pasting text from the product description and not highlighting the whole thing that listed all the other motor codes.
2016 Camaro 2ss
10-13-2018, 08:58 PM | #4 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
You only need to remove heads and oil pan to access the connecting rod bolts and pop the pistons out. One piece exact size ring compressors make the job just a little easier. I would do head studs, but that's just me.
'18 1SS 1LE Black, PDR
10-13-2018, 10:30 PM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
would be interested in the recommended honing procedure... I'm used to plateau honing.
10-14-2018, 07:08 AM | #6 |
Is yours a M6 or A8? If its an A8 you can have it out of the car in about 7 hours and that includes taking all the accys off.
10-14-2018, 08:13 AM | #7 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
How long for a m6?
Baby Blue
10-14-2018, 10:42 AM | #8 |
The M6 needs the trans dropped, it maybe able to do it with dropping the subframe 4" the problem is you can't yank it the engine out as the double clutch pack binds between the trans housing and thus the pan can't clear the K member. You may on an M6 consider taking the pan off first. Now that I have BMR engine mounts it is about 1.5 hour job to drop the pan.
For the M6 I would seriously think about dropping the engine and trans from the bottom.
10-14-2018, 11:02 AM | #9 |
What old man said.
10-14-2018, 01:31 PM | #10 | |
Baby Blue
10-14-2018, 03:05 PM | #11 |
Don't know about the knock retard, there is a little more vibration, it is hard to tell because I did the cam at the same time.
10-15-2018, 01:32 PM | #12 |
It's an A8.
2016 Camaro 2ss
10-30-2018, 01:26 PM | #13 |
Update - my mechanics ended up pulling the motor. They also found chunks of my primary cats loose in the exhaust so I ended up replacing with Kooks Long Tubes and Cats.
Car should be done early next week.
2016 Camaro 2ss
01-22-2019, 01:13 PM | #14 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
how did it turn out?
