02-02-2019, 04:54 PM | #1 |
Drives: ZL1 1LE Join Date: Aug 2018
Help - what is this screw on hub?
Rookie question. Finally putting PS4s on and when removing wheel this screw fell out. Put it back in, but any idea what it’s for? And should I be freaked out it just fell out? 😬
02-02-2019, 05:01 PM | #2 |
Drives: 2017 ZL1 6MT Join Date: Feb 2018
It's for holding the rotor in place to the hub.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
02-02-2019, 05:03 PM | #3 |
Retired from Car mfrs....
It should go back in with Loctite.
02-02-2019, 06:44 PM | #4 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
It’s not the end of the world that it was loose. As long as your lug nuts are torqued to spec that brake rotor is not going anywhere.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
02-02-2019, 08:11 PM | #5 |
Its used on the assembly line to keep the rotor in place the car is being built
02-02-2019, 08:17 PM | #6 |
that little bastard of a screw is usually mega torqued with loctite from the factory
02-02-2019, 09:05 PM | #7 |
Who Needs to KNOW?
Keep rotor in place, otherwise you need 3rd hand when doing rotor/pads overhaul.
ing for grip.
02-02-2019, 11:44 PM | #8 |
Thanks for clarifying - I was having a WTF moment. 😂. BTW - the PS4s are money. The car’s not nearly as sharp as with the 3Rs but at least I can use up to 50% throttle without an anxiety attack this time of year.
02-03-2019, 06:45 AM | #9 |
Bannable
it 100% does NOT have to go back in. It is there only to ease assembly at the factory. There are no negative effects from ditching it. In fact, they are a royal pain if they seize. So, first rotor change I do they go bye-bye
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's Last edited by Torquem; 02-03-2019 at 06:56 AM. |
02-03-2019, 08:12 AM | #10 |
^^^This
02-04-2019, 10:40 AM | #11 |
Drives: 2014 ATS 2.0T 6MT Join Date: Mar 2018
I keep em around but I never use locktite... there is enough dissimilar metal corrosion going on in that area the last thing it needs to be is tighter. I use never-seize. They really dont back out and are often trapped by the wheel anyway.
While you are at it, wire wheel and never-seize the hub surface and possibly the wheel. Those rotors look like they have some heat to them... |
02-09-2019, 09:53 PM | #12 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
+1 on the PS4's- big step up from the stock Goodyears on my SS!
02-15-2019, 08:24 AM | #13 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
NNNNOOOOOOOOOO!!!!
02-15-2019, 09:39 AM | #14 |
Agree with the idea of anti-seize. These things always corrode. They are really the only fastener for which I routinely have to break out the impact screwdriver.
