Old 05-26-2018, 05:20 PM   #15
Roasted7
Roasted7's Avatar
Drives: 2016 2SS
Been wanting to try these tires soooo bad but pretty much everyone I know says 2 track days and done. So I think i'm going to try the Hoosier R7's next and hopefully get 4 track days
Roasted7 is offline   Reply With Quote
Old 05-27-2018, 10:12 AM   #16
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
That's not true. 2 track days? No....I suppose it depends on the track and how you drive, but mine lasted for 2 track days, the equivalent of 3 autocrosses, and 4000 street miles.
I just went to Pocono with a new set, and they've got "tons" (relatively speaking) tread left.
I'm also real curious if the alignment we did will prevent, or reduce the inside cording a lot of people are experiencing.
Old 05-28-2018, 08:47 PM   #17
Matos1LE
Drives: SS 1LE
Originally Posted by Provoste View Post
Huh?
I'd read somewhere that the MRC has a ride height setting. Since the 19's cause the car to sit lower, you had to have the suspension height setting zero'd so it would work optimally. This is coming from one of the guys on the facebook page who autocrosses/tracks often. I would love to hear that he's completely wrong and it doesn't matter at all, I'll have 19's in no time if that's the case!
Matos1LE is offline   Reply With Quote
Old 05-30-2018, 09:32 PM   #18
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Uh, no... dead wrong. I run 18’s, 19’s and 20’s on my SS 1LE. Search some of my posts, I “track often”.
Provoste is offline   Reply With Quote
Old 05-31-2018, 07:57 AM   #19
Mr. Wyndham
I've heard both stories, and haven't seen a confirmation on either one.
There are ride-height sensors at each corner to provide feedback for the operation of MRC. But what I'm unsure of is if the system cares where "zero" is. Some take the time to put in shorter "end links" when they lower the car with springs. Others don't care and say it works fine.
That all said - the wheel/tire height will not affect this sensor...because so long as the suspension remains unchanged, the position of the spindle relative to the car will remain the same no matter what size wheel & tire you're using.
Old 05-31-2018, 08:12 AM   #20
Provoste
Provoste's Avatar
One thing about MRC that I will tell you, is that when any of the wheels are in the air at full droop (when jacked up or on a lift), the suspension doesn't return the car to normal ride height until you start drivng the car. It lowers the suspension ~ 1.5-2 inches as you start to drive. It does this automatically, regardless of 18-20" wheel/tire size.
Old 05-31-2018, 09:35 AM   #21
Mr. Wyndham
That's primarily a function of the bushings, and stiff sidewalls, all of my Camaros have done that to varying degrees. The MRC pistons basically have open holes in them, so there's really nothing to prevent/restrict fluid flow until the system comes online and the EM coils energize.
Old 05-31-2018, 09:54 AM   #22
Provoste
Provoste's Avatar
No, this is not a bushing function/sidewall etc. I’ve jacked up many many many cars in my day. This is a mechanical function you can see take place as the car starts to drive in the 3-5mph range.
Old 05-31-2018, 10:07 AM   #23
Mr. Wyndham
if you say so...I never experienced that with MR. It has no right-height adjustability, simply damping rates. So I'm not sure what it is...maybe the fluid gets extra viscous or something? Haven't heard of that before.
Old 05-31-2018, 10:52 AM   #24
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I have a lift and have never noticed a temp increase in ride height when I set the car back down. I put it on the lift after each track event. I’ll measure before and after Saturday when I raise / lower it.
RUQWIKR is offline   Reply With Quote
Old 05-31-2018, 12:07 PM   #25
Provoste
Provoste's Avatar
Yeah I'm not sure either. It's actually funny, when I swap wheels at the track, I've had friends gather and watch to watch it lower as I drive away. It definitly has something to do with the MRC.
ZL1 1LE, 964, Boxster S, 997, GT4 and every other car I've ever worked on have behaved just like you originally described.... where you need to roll them a tad to get a fully accurate ride height/alignment representation. Its different w/ the SS 1LE.
Old 05-31-2018, 12:12 PM   #26
Mr. Wyndham
I've got to see this, now! I had MRC on my 2012 ZL1. And watched a shop lift and set back down a 2017 ZL1...and never saw/heard about this phenomenon you're describing. This is new to me!
Old 05-31-2018, 12:18 PM   #27
Provoste
Provoste's Avatar
I need to put new front pads on my SS 1LE tonight, I'll measure before jacking up, and right after. I'll take pictures too.
Old 05-31-2018, 01:28 PM   #28
Mountain
Mountain's Avatar
I've heard otherwise, by Ryphile, who just got done trying the SC 3R's, that they are not really much better than the SC 3 tires. The comments were that the SC 3R had a more vague feel with peaky-er grip and less talky/communicative, where the SC 3 had better feel, more consistent grip and were a lot more communicative.
After doing a track day in 90F+, full sun weather, not having ANY issues with the SC 3 tires, I see zero need to deviate from them. They seem sensitive to getting air pressure right, so that might be something that has lead to people being turned off by them? But, get the pressure right and they are SWEET. They do pretty decent in autocross, too. Obviously not an RE71R, but pretty good still.
