01-14-2018, 09:40 AM | #1 |
Driver for Hire
Wilwood Rotor Rings on 1LE SS?
I did a search and didn’t find any results. Has anyone tried the Wilwood replacement rotor rings in their 1LE SS or ZL1?
https://www.carid.com/2017-chevy-cam...639686546.html http://www.wilwood.com/Rotors/RotorP...o=160-13472-BK Has anyone found a slotted rotor for the rear brakes yet? Asking all of this for a friend with a 2017 1LE SS, and I am a potential future 1LE SS owner, so all feedback is appreciated. Last edited by FollowMyLine; 01-14-2018 at 09:46 AM. Reason: Added link from Wilwood |
01-14-2018, 10:14 AM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Second link doesn’t work.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
01-14-2018, 12:18 PM | #3 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I believe those rotors are to be used with their hats on their big brake kits. Without the rest of the kit they won't work. I have their kit, and they perform well on the road course but after 30 or so race hours the fronts are at minimum thickness and will need to be replaced before next season. This wear is mostly from the use of the polymatrix H compound pad full time...even while daily driving the car. I would recommend their stuff but with the 1LE already having good brakes I would work through GM and get the rotors for that setup.
01-14-2018, 12:29 PM | #4 |
Driver for Hire
01-14-2018, 12:31 PM | #5 | |
Driver for Hire
01-17-2018, 01:25 PM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
DBA makes replacement rings for the SS 1LE brakes. Glamcem documented it very well, look in his build thread for part numbers. That said, the rings alone aren't much less than buying new OEM complete rotors w/hats. Most of the online GM parts places don't have SS 1LE updated, so search for ATS-V front rotors, they're identical.
SS 1LE rotors are 370mm diameter, roughly 14.6", FYI.
01-18-2018, 03:01 PM | #7 | |
Driver for Hire
01-18-2018, 03:05 PM | #8 |
i also been talking to dba about rotors for the ss and 1le but still waiting on update
01-18-2018, 04:57 PM | #9 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
another place you may wanna try.... if nothing has come to fruition.... is TCE Performance. Todd specializes in braking for almost any car. they usually do wilwood kits, or piece together kits for cars that otherwise would never have em. hes done everything from caliper only kits with stock rotors, to 2 piece rotors for stock calipers, and full 4-6 piston setups for all the odd cars that most don't even bat an eye at.
getting a rotor hat and disc combo to fit is something he would be able to help with. on the charger, I ran the W6a 6 pistons on SRT stock rotors, with the mount he designed and milled. it was a big seller on the LX forums. and I went through him for the Aero6 caliper setup for the 2013 Camaro LS I had, before the 6th gen. worth a shot if there is interest.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
01-18-2018, 06:23 PM | #10 |
Driver for Hire
Looks like the DBA rotor rings for the Corvette are the way to go. Also, looks like RacingBrake has a solution, albeit very expensive.
01-19-2018, 06:13 AM | #11 |
Chin Event Manager
Drives: 2018 SS 1LE Join Date: Dec 2011
Does anyone have a measured drawing of the stock rings? Coleman racing will be able to make rings. I've gotten rotors from them for a couple of different cars. They can quote from a drawing of you can send in an old ring.
Jim Pomroy
Chin Track Days Chief Instructor and Event Manager 2018 1LE 2015 Mustang GTPP 2011 Duramax Access to several Chin track cars... |
02-07-2019, 11:31 PM | #12 |
Wilwood brakes
Wilwood aero 6 kit, this picture was taken after 1 weekend at Sebring Fl (track weekend with nasa hpde 4) I bought this kit new from wilwood.
DO NOT BUY Wilwood Brakes... Wilwood Customer services are the worse! Brembo are the best! I’ll install my brembos back! Don’t make the same expensive mistake. Last edited by JC 1LE; 02-09-2019 at 07:15 AM. |
