03-23-2018, 06:21 PM | #15 |
5w30 street & 5w40 track use and no oil usage thus far
03-23-2018, 07:01 PM | #16 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
It takes a long time for the oil to drain out cold.
03-23-2018, 07:03 PM | #17 | ||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
You guys should not be using that much oil. If you're using that much oil, especially if you see bursts of bluish smoke when you mash the gas, your piston rings may not have seated properly during break-in. It's also possible you have a clogged or malfunctioning PCV valve, resulting in excessive pressure build-up in the crankcase. I would expect the ECM to throw a code if this were the case, though. If you're truly getting dark black smoke that's a separate problem. It's most likely from un-burned fuel. Look for clogged air filter or fuel system restrictions. The viscosity of the oil will not have a measurable effect on the amount of oil you burn. When your engine is warmed up 40 weight oil will get sucked past the rings almost as easily as 30 weight if they're not seated. --Cal |
03-23-2018, 07:22 PM | #18 | |
Drives: 2018 ZL1 Join Date: Feb 2018
Past Rides 13 Porsche 911 4S 17 BMW M4 16 Shelby GT 350 07 Saleen Mustang 02 M3 Comp Pack 79 Corvette |
03-23-2018, 08:56 PM | #19 |
Drives: 2017 Camaro ZL1, M6 Join Date: Aug 2017
I broke mine in pretty much by the book and have run it pretty hard since. After the 1500 mile oil change, I added a half quart at 3500 miles. It would be interesting what impact, if any, the break-in has on oil consumption. I would think the driving style would be the biggest factor. As others have noted, running it hard probably translates into higher oil consumption. I blow some smoke every time I do first through third gear pulls, shifting at redline.
I’ve had a number of vehicles in the past use more oil than I would like or expect from new, but they have all been the higher horsepower vehicles. I’ve stopped letting it bother me, unless the consumption is over a quart per thousand miles. The Z06 forums probably have some good “data” on LT4 oil consumption. |
03-23-2018, 09:02 PM | #20 | |
03-23-2018, 09:23 PM | #21 |
Thank you Al Oppenheiser!
1600 mi since the first oil chance and hasn’t used a drop under spirited driving.
03-23-2018, 10:14 PM | #22 |
Drives: ZL 1 2018, BMW M4 Comp. 19, Z4 M 06 Join Date: Dec 2017
Guys zero, nada, cero OIL !?
Think oil is the blood for the engine, so no consumption, something wrong, same with too much (sealer) |
03-23-2018, 10:30 PM | #23 |
The higher rpm u run the engine the more oil u burn. With paddles and rev match I would bet a lot of ppl engine brake more than ever which eats oil
03-24-2018, 07:05 AM | #24 | |
Cal
You won't get any scientific certainty on any forums as this is always a hot topic with strong opinions on both sides. You will get lots of anecdotes and unqualified opinions. All I can say with certainty is what seems to have worked for me. IMHO, excessive oil consumption and bluish smoke is a classic side-effect from a passive break-in. It's usually accompanied by lower cylinder compression resulting in reduced performance and lower fuel economy. Like most things, people need to do their own research and decide for themselves what's best for them. --Cal |
03-24-2018, 08:55 AM | #25 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
It was low so i kept adding oil slowly until it came up and that is what I added.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
03-24-2018, 11:34 PM | #26 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
changed my oil at 1500 miles. I'm at 8500 miles now. 22% left on the Life meter.
I checked my oil today because of this post. DOWN A QUART at 7k miles. I do use rev match and drive well over the speed limit.
ZL1::J-E-T-S JETS JETS JETS |
03-24-2018, 11:55 PM | #27 |
Drives: ///M3 Join Date: Nov 2016
5k miles. Broken in properly and 95% track miles. Zero oil consumption.
03-25-2018, 05:43 AM | #28 |
Drives: 17 ZL1 Join Date: Mar 2017
22% on the oil life meter, why do you wait that long?
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
