dave@hennessey
Old 05-28-2010, 10:01 PM   #15
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Do you guys do your own tuning?
What kind of dyno was used?
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 06-02-2010, 01:08 PM   #16
rt66
Drives: 2010 Nickey Chicago Camaro
THE VIDEO IS HERE
rt66 is offline   Reply With Quote
Old 06-02-2010, 02:35 PM   #17
SonnyakaPig
Drives: C63 P31
Nice video. Thanks for sharing.
I couldn't see the results in the dyno sheets. Are you able to post them as images? I couldn't read the numbers on the sheets either. I did hear you say what the numbers were, but I am interested in seeing the numbers next to the rpms.
Do you mind sharing how much peak boost is needed to make the final numbers? Also, what is the AFR during the runs?
Thanks, and you guys have some great cars on your website. Especially that American Heroes III car. Wow, very cool.
SonnyakaPig is offline   Reply With Quote
Old 06-02-2010, 03:15 PM   #18
rt66
The sheets are posted below - Also we needed about a 6lb. boost to make the final numbers, but with the automatics they have a smaller boost pulley than manuals. You will be able to see the AFR on the sheets below
Thank you as well for the compliment on our cars!
Sheets are in order as you seen them in the video as well
2010 camaro, e-force, edelbrock, route 66 motorsports, super charger
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
DIY : Install Performance Swaybars in 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 17 09-14-2015 12:36 AM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Answeres to questions I have stumbled on dieseldave24v 5th Gen Camaro SS LS LT General Discussions 13 02-23-2009 06:56 PM
