11-18-2018, 04:44 PM | #57 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Cai
The stock one is one piece so you can't get it wrong but most of the aftermarket ones need the maf tube to be clocked to a certain orientation. The gm and cai one have mark's on the tube and air box that need to be lined up. Just looking at yours it looks 10 to 20 degrees off. Compare it to the image posted a few messages up comparing the gm parts guy one vs yours. Idk if that would in anyway account for the power loss but I have been told maf orientation is important in these cars and maybe that combined with it not being calibrated correctly is the problem. |
11-19-2018, 04:48 PM | #58 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
RobbyBeefcake87: No argument from me. The MAF was indeed off as you mentioned - corrected and didn't seem to pick up 30-100 HP on the next drive. I wish it were that easy - still important.
11-19-2018, 04:54 PM | #59 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Electricial issues can present themselves in very mysterious ways. Case in point, I worked at Tesla in Engineering doing reliability and test. My model X would throw a bunch of faults at times and not function properly. Most notably during a hot humid chamber cycle. After many hours of looking and performing the wiggle test, we found the culprit, one of the connectors had gotten damaged during assembly and under the right conditions it would fail the electrical connection. There wasn't enough pin retention to allow for proper connection all the time. So when I see damage to a connector like that it throws a huge red flag to me. It is also possible that the MAF got damaged. They aren't a very robust part. And if the installer damaged the connector, it's possible they weren't too careful with the MAF either. It's just a thought based on my past experiences.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
11-19-2018, 05:48 PM | #60 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Have you done a leakdown test yet?
11-20-2018, 07:27 PM | #61 |
Whocares05050: not equipped for a leak down. Do have a compression gauge, but am hesitant doing so. No oil useage, no residue on the rear of the car, no discernible smoke. What is the spec for an LT1?
Car will be dynoed again tomorrow hopefully with another 1LE for direct comparison. Thanks. |
11-21-2018, 06:50 AM | #62 | |
11-21-2018, 08:48 AM | #63 | |
Drives: Black Join Date: Jan 2017
Never heard of cylinder getting extremely low compression without other symptoms. His power loss is huge, surely if it failed enough to cause that low of power he'd have other symptoms |
11-21-2018, 09:00 AM | #64 |
ok so you have reduced power but are not setting any codes, there are not many things that would not set off the CEL.
I'm thinking it's some sort of blockage in the exhaust or intake. Do you have NPP? maybe the NPP valves aren't opening up? I suppose you could hear that though. Maybe try disconnecting your exhaust as close to the headers as possible and try a pull to eliminate a blockage? For all you know someone shoved something in your exhaust. Also maybe try disconnecting your air filter, who knows maybe some idiot sprayed it with something they shouldn't have. Maybe your cats are clogged? Also you should be able to tell if your intake path is blocked somehow by a WOT vacuum reading. Sometimes intakes are tested that way. Less vacuum = more flow. Torque app with bluetooth dongle would be helpful. You can read all the sensors. Could be something as simple as a fuel filter, but I'd think you'd get codes if that were the case. |
11-21-2018, 09:21 AM | #65 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Sorry you are having to deal with this, certainly does appear you have a dud. How did you verify the tune was correct? If the dealer installed it that IMO is a huge red flag just because dealerships, by in large, suck.
Can the shop you are Dyno'd at re-tune it?
11-21-2018, 09:23 AM | #66 | |
11-21-2018, 10:27 AM | #67 |
Drives: A few Join Date: Oct 2017
It's the official GM tune for the intake. Probably not that easy to screw up.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
11-21-2018, 11:48 AM | #68 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
It's either a go or no go situation. Stock tune or CAI tune. You really can't half ass a reflash.
'18 1SS 1LE Black, PDR
11-21-2018, 12:22 PM | #69 |
I'm sticking by my previous mention, This is an electrical problem. Damage to wiring, sloppy CAI install, AFR on dyno sheet is wonky (18:1 from 3-4 k rpm then slowly climbing to about 11:1 at 6100 rpm). The three things I'd verify first are that the proper tune was installed with the CAI(GM did say that the change in MAF location effects the vehicle and needs a new tune), make sure the wires in the connector are not damaged and check the terminals in the connector to make sure they aren't deformed, Check the MAF with a known good one if possible.
A plugged cat, unless it's a secondary cat, should set off a MIL. I don't think a plugged cat nor low compression would make the AFR vary so drastically and in the exact same pattern for 3 dyno pulls.
11-21-2018, 12:28 PM | #70 |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
