12-16-2022, 08:18 AM | #1 |
***SOLD***Coil Relocation Kits w/Plug Wires
Selling this coil relocation kit that includes the brackets, spacers and Scott Performance 10mm plug wires. The plug wires are about 4 months old.
All parts are used and in working condition. The #6 wire does have the shrink wrap cracked but the wire isn't damaged at all. These work like they should. The coil extension wire harness is 36" long which is long enough to mount on the front frame rails. The plug wires are designed to go under the header from the front of the engine, so mounting the coil brackets on the front frame rails works well. Here is a link to the wires - https://sparkplugwires.com/chevy-ct5...et-uh-af-long/ Asking $OLD shipped for all. Please PM if interested. Going back to valve cover mounted coils is the reason for selling.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP Last edited by Ashen 6.2; 12-17-2022 at 01:04 PM. |
12-17-2022, 11:33 AM | #2 |
Drives: 2011 Camaro SS Join Date: Jul 2017
You have a PM.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
12-17-2022, 12:30 PM | #3 |
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
