Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 05-10-2017, 01:52 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
High RPM on an LS V8
In town there is an EFI school, and it run by a guy that was a pro stock driver, found this today on his work with comp cam and making an LS spin 11K and where there at now.
http://www.enginelabs.com/news/efi-u...ct-spinal-tap/
2SSRS@Gen5diy is offline   Reply With Quote
Old 05-10-2017, 01:58 PM   #2
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I guess I don't really see the need to have something like this around. You can make a great bracket racer that only spins to 7k if you want. This is my favorite part of the article:
The goal is for the project to eventually be dropped into a Fox-body Mustang for no-prep grudge races and bracket events.
Thanks for sharing.
Eric SS is offline   Reply With Quote
Old 05-10-2017, 02:41 PM   #3
2SSRS@Gen5diy
If you road race more RPM with power the less shifting if the Z/28 went to 8500RPM no need for 5th gear on a 3 Mi track with turns,
Old 05-10-2017, 02:46 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
I agree with you when it comes to road racing, but the article said the car is for bracket racing.
Old 05-10-2017, 03:18 PM   #5
2SSRS@Gen5diy
Thats there plan, but if this works and you can safely move the RPM up on a road car then we are that much better off, no?
Old 05-10-2017, 03:20 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
Hey, I'm down for testing the limits like this for sure! Why not? And Jesel makes great rocker arm systems. I just thought it was an interesting application to be doing it on. Hell, might as well try to go with pneumatic valves at that point.
Old 05-10-2017, 04:57 PM   #7
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
Pretty awesome, would like to see/hear the final product on the dyno.
GrimReaperSS is offline   Reply With Quote
Old 05-12-2017, 09:47 AM   #8
Goobaba
Drives: 2016 V6 RS Manual
Jesus thats bananas! I'm always a fan of "let's do it for the sake of doing it" projects
Goobaba is offline   Reply With Quote
Old 05-12-2017, 09:54 AM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
But even while road racing...more torque down low makes up for the less shifting with a high rpm engine. Check out the Head-to-Head M6 v A10 ZL1 lap...the LT4 make so much torque, it could just run out the gears, even at lower rpms.
C7.R does damn well in competition with a 6000-some redline.
Typically, high torque engines are larger displacement, and have a lower relative redline. And a low-torque engine needs to spin higher to make up the performance, like the Voodoo engine in Mustang.
The LS7 was that "sweet spot", balancing high RPMs, with high torque. There hasn't been an engine since then that could do the same sort of thing.
You'll rarely find both in the same package...would be wicked if this "Spin Tron" was reliable.
Old 05-12-2017, 01:23 PM   #10
2SSRS@Gen5diy
And more news today, there is a NASA (retired) engineer out there that with his sound equipment came up with this, the new ZR1 is shifting at 9000 RPM, so this may not be that far out if its true.
found the link hope it ok to post.
http://www.corvetteblogger.com/2017/...ting-9000-rpms
Old 05-12-2017, 02:56 PM   #11
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Should we cancel our ZL1 1LE orders and wait for the Z/28 with this engine?
Old 05-12-2017, 03:07 PM   #12
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
That's pretty interesting! Guess time will tell if true.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 05-12-2017, 03:27 PM   #13
2SSRS@Gen5diy
I did not say that, from what i know from talking to people in the trade there are better engine in the works,
Old 05-12-2017, 04:10 PM   #14
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
I didn't mean to imply that you did. I was merely being facetious.
