02-28-2017, 01:21 PM | #15 | |
Drives: 2015 Z/28 #1097 Join Date: Jan 2010
In theory, the Z/28 would be a track car for the street. Might be faster than the ZL1 on some tracks, might not on others. Would be less comfortable, lighter, less power, n/a. |
02-28-2017, 03:05 PM | #16 |
Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
I dont feel a potential new "Z/28" will need to out power the ZL1 1LE. NOW, that doesnt mean it cant out perform it.. the Corvette has made use of Carbon fiber components regularly for the last two generations. A Z/28 could be a potential benefactor in this where the roof, hood, front fenders, side skirts, spoilers etc could be made with it. The GT350 showed that other components for the vehicle structure/supports could be change to it as well (radiator/core support). The material is not as pricey as it once was. With the addition of an higher powered (more than the SS) NA engine and a dramatic weight decrease, it would scream! How much lateral grip would it have if it were another 200-300(?) lbs off the weight of the ZL1 1LE due to less body weight and less engine weight (no supercharger and associated components), while using the same suspension and wheels/tires?
02-28-2017, 03:22 PM | #17 | |
I used to be Dragoneye...
A "regular" ZL1 is 3883. 6 of those pounds is in the wheels/tires...the rest is split between the suspension, rear glass, and removal the foldable rear seat. (all of which would theoretically be part of the Z/28 package. So let's take 3747 (SS 1LE), and subtract 63 lbs...to pretend we put on the DSSV dampers, stopped the rear seats from folding down, and installed lighter glass: 3684 lb theoretical Z/28 with not luxury options, and the lightest weight of engine and suspension components. 3820 (ZL1 1LE) - 3684 (Hyp. Z/28) = 136 lbs. Perhaps we could find 10-15 or so in the base-level speaker system. You'd need to find 64 more lbs to hit your 200 less mark...164 to hit the 300 mark. CF isn't as expensive as it used to be....but it will be very expensive to use enough to pull 64-164 more pounds out of the car. But I admit...it would be intriguing to see what a 550 hp naturally aspirated, 3520 lb Camaro could do. I wouldn't be intrigued to pay the price for that, though. |
02-28-2017, 03:27 PM | #18 | |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
My feeling is that the Z/28 could become the "Pure Drivers Camaro", think Porsche 911R.
02-28-2017, 03:34 PM | #19 | |
Hmm...possibly. But doesn't the 911R utilize the same engine/powertrain as the GT3? My understanding (and it's not a thorough one) is that the major difference between the two is the manual transmission. |
02-28-2017, 03:37 PM | #20 | |
02-28-2017, 03:39 PM | #21 |
911R also does not have the large aero components of the GT3 or RS.
03-01-2017, 05:36 AM | #22 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
03-01-2017, 07:36 AM | #23 | |||
Yeah - something like that could be very interesting...I just wonder if it'd be enough. Quote:
If you see our example above...what you'd end up with by doing this is a car that's slower than the ZL1 1LE...UNLESS...you extensively use light-weighting stuff like carbon fiber to compensate. So I guess some folks (if that doesn't matter)...simply want a N/A engine, and don't care what the performance is? |
03-01-2017, 09:09 AM | #24 | ||
Drives: 21 Bronco Join Date: Jun 2012
IMO The Z/28 should be a track focused model, but IMO it doesn't need to follow the 5th gens formula, (being so extreme). This is just my opinion (and I know it won't be a popular one) but the Z/28 doesn't need to be the halo camaro |
03-01-2017, 09:24 AM | #25 |
I think some of the issue is that we have no GT350 or GT350R competitor. The SS is for the GT. The 1LE just trounces it more (I think Ford might release a Mach 1 to match). The ZL1 is way better than the GT350R is almost every metric and would be better suited to compete against their GT500. Since they tend to match up against each other, helping both brands, I would think that there is still room to match against a gt350r in an N/A platform.
I might be have a different opinion on how these cars match up, but I think there might be a misconception just because the Camaro is far ahead of the Mustang for this generation (so the Camaro tends to be scaled up in which model it competes against) |
03-01-2017, 10:01 AM | #26 | |
03-01-2017, 10:05 AM | #27 |
because the 5th gen made the Z/28 the "halo" car of the lineup
03-01-2017, 10:09 AM | #28 |
It doesn't and it's not... in a straight line.
Road track yes since that's it's sole purpose. |
