10-12-2018, 10:14 AM | #1 |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
Oil change in driveway
Ok folks, I need to change my oil for track duty next week, and I am contemplating using the race ramps wheel cribs pictured below. Anyone use them? My driveway is gravel so I can't use a quickjack or anything just yet (I am going to borrow my neighbors concrete pad for now).
For now I am contemplating going with this. I guess my question is, any driveway changers in here? Anyone have the issue I have i.e. having a flat driveway and no easy way to get the car up and level? (not a jackstand fan). |
10-12-2018, 11:26 AM | #2 |
Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
Change mine all the time in the garage on jack stands, just make sure car is level.
10-12-2018, 11:38 AM | #3 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
From my and others experiences our cars do not have to be level for all the oil to drain. I made my own wheel cribs out of 10"x10" solid wood blocks and jack the front up with two jacks. Works great.
You know you are having fun when you are getting 3.4 mpg !!
10-12-2018, 12:59 PM | #4 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
Made my own ramps out of 2"x10" planks. It's a pain with the car being so low and having a belly pan to remove. There is a couple of threads on how to, here is a picture of a members homemade ramps. Mine are similar but are like 7ft long to be able to clear the Z28 splitter. I made them so each ramp is two pieces, I can use one for normal height cars and then add the extension to do my 1le. They are heavy.
10-12-2018, 01:41 PM | #5 | |
Anyone else not leveling the car for oil changes? |
10-12-2018, 01:51 PM | #6 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
those wooden ramps look exacty like mine, i use those too since I can barey get lift jack under my car how low it is.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
10-12-2018, 02:15 PM | #7 |
Build Date - Dec 08, 2014
Drives: 2015 Z/28, #1007, Black A/C Stereo Join Date: Oct 2015
A word of caution, race ramp product data indicates to only use on flat surfaces, being that said I have used mine multiple times on an inclined driveway. You can easily find yourself in a difficult position getting the car back off the race ramps when at an incline depending on the steepness of the grade and the car being a standard, it is gonna roll and you can't aggressively left off the clutch.
10-12-2018, 04:11 PM | #8 | |
I measured how much came out being not level and it was just about exactly what we put in. I don't level it anymore for oil changes.
10-12-2018, 07:26 PM | #9 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
I use 2 low profile jacks from harbor freight, one on each side. Get the front up in the air. 2 jacks stands for safety. All 10 qts drain, no problem.
My brother's c6 z06 is done the same way as well
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
10-13-2018, 07:01 AM | #10 |
Drives: 2015 Z/28 #898 Join Date: Oct 2016
So Jon,
You ONLY get the front of the car up correct? |
10-13-2018, 08:34 AM | #11 |
10-13-2018, 08:45 AM | #12 |
Drives: 2015 White Z28 Join Date: Aug 2018
Off subject a little, do you have jack pads on the seam welds or do you just use the hockey pucks on the seam welds to lift the car?
10-13-2018, 09:21 AM | #13 |
Drives: 2SS/RS Join Date: Sep 2008
I have a gravel driveway as well and I use jacks, jack stands, and race ramps all the time and never had any issues. Just put a piece of 1/2" plywood under them that is big enough to support the weight and if using a jack, is big enough so the jack doesn't roll off.
10-13-2018, 03:12 PM | #14 | |
Only the front is up
I have the seam jack pad from zl1 add ons. You gotta use them or get jacks with a longer reach to get to jack spots further inboard on the car
Current:
