02-07-2017, 01:52 PM | #57 | ||
Drives: 16 Camaro SS Join Date: Nov 2015
I purchased from Rydell - Service has always been at Keyes Chevy. |
02-27-2017, 01:57 PM | #58 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
Primary and Secondary cats deleted, can't tell if Rasp or Rattle lol. Likely going to plug resonators mid way and then ultimately hope that the aftermarket NPP options have stronger valves
02-27-2017, 02:21 PM | #59 |
You planning on slp loudmouth 1 mufflers/resonators?
02-27-2017, 05:41 PM | #60 |
03-09-2017, 08:16 PM | #61 |
Drives: 2016 Camaro 2SS Summit White Join Date: Dec 2015
GM won't do anything. The run around and total lack of customer service I have received their "customer care" team is pathetic. They maintain the rattle is "normal" but refuse to put that position in writing. No explanation why they issued a service bulletin for a "normal" exhaust rattle.
04-10-2017, 06:57 AM | #62 | |
Drives: 2016 Camaro 2SS Join Date: May 2016
Has anyone successfully performed this procedure themselves? I tried to do it this weekend, but my car does not allow me to change the driving mode while in Accessory mode (i.e. I cannot close the exhaust valves with the car turned off). |
04-10-2017, 10:10 PM | #63 |
Drives: 2016 2SS Nightfall Grey Join Date: Dec 2016
you have to press the ignition button without your foot on the brake for 5 seconds until the little light on the button turns green. That puts it into maintenance mode, where it acts as though the engine is on so you can change all the settings, without actually tuning on the engine. Let me know how it turns out for you. I'm planning on trying this fix myself as well.
04-10-2017, 10:21 PM | #64 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Eh epoxy is strong but not when there are elevated temperatures.
The epoxy is rated up to 224F/ 107C that's decent but the exhaust does get decently hot so. |
04-10-2017, 11:59 PM | #65 | |
Drives: X-15 Velocipede Join Date: Mar 2008
https://www.jbweld.com/products/highheat-epoxy-putty Clean per bulletin first https://www.amazon.com/TEKTON-7064-B.../dp/B0037UUZRS
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. Last edited by camaro5; 04-11-2017 at 02:54 AM. |
04-11-2017, 02:28 PM | #66 | |
Regardless, I triple cleaned the areas noted in the TSB and applied the referenced epoxy (I believe epoxy cost me $15). After waiting 24hrs for the product to cure, I took the car for spin and it still buzzes. Is it better, yes, maybe 30% or so. I've gone through the procedure twice, same result. Pretty disappointing.... I'm bringing it to the dealer in the near future, I want a new exhaust if they can't fix it. |
04-11-2017, 03:53 PM | #67 |
I am on my third set, The first they flat out replaced under warranty, the second the put the epoxy on, after about 3 months, the rattle came back, so they replaced it again.
04-12-2017, 11:51 AM | #68 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Do any 2017 models have this issue? I have not heard anything out of the ordinary on my recently purchased 1SS.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
04-14-2017, 07:27 AM | #69 |
Drives: 2016 Camaro 2SS Join Date: Apr 2016
This is so sad... I waited a while to see if GM would have an acceptable solution but nothing yet.
04-18-2017, 07:25 AM | #70 | |
Thanks for the tip. It would have been nice if Chevy would have correctly written the service bulletin. I applied the epoxy this weekend, and it did not alleviate the rattle that I am experiencing. At least the exhaust rattle distracts me from the wind noise that Chevy has been unable to correct for almost a year now. |
