08-13-2012, 08:07 AM | #295 | |||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
Slightly slower speeds... 24mpg... I can dream... lol maybe if I throw on two Gear Vendors' overdrive units
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
08-15-2012, 07:06 PM | #296 | |
ace5.org
But I'm back at school now so I'm back to getting 14 MPG.
Stock...For Now.
09-03-2012, 08:55 AM | #297 | |||
Truth Enforcer
my truck is big... compared to your car... but compared to Oracles GMC Topkick... Tires are actually not that "big". the wheels are 16's... which I am wanting to change out for something a little taller. Was looking into some 19.5" wheels with some commercial grade tires for all the driving I do in the truck. (changed my oil the tuesday before the fest... I'm just about to cross 10k more miles this week...) and my engine is smaller than yours... 6.2>6.0L
09-03-2012, 10:50 AM | #298 | |
ace5.org
That's a lot of driving. I'm just barely over the 10k mark in my car let alone in a month. Well I guess that's two things going for me then. Bigger engine, better highway miles. I just calculated my MPGs since being back in auburn...I'm getting about 10 MPG. Solid.
Stock...For Now.
09-03-2012, 11:00 AM | #299 | |||
Truth Enforcer
my average fuel economy is around 12mpg or so. highway doing "my 10mph over" nets me around 14 or so and city miles are around 10 with or without a load. the damn thing drives like a diesel. planning on sealing the underbody of the truck off and custom fabbing a lower air dam to streamline the airflow around the truck.
09-03-2012, 11:24 AM | #300 | |
ace5.org
Stock...For Now.
09-04-2012, 07:00 AM | #301 | |||
Truth Enforcer
remember, I'm an ME specializing in aeronautical engineering... and I love to make/invent/etc things not to mention, if it can help get an 8XXXlbs diesel truck to hit 180+mph on the salt flats, it should help me with a few mpg on the highway. looks be damned. http://www.dieselpowermag.com/featur.../photo_01.html http://www.dieselpowermag.com/featur.../photo_04.html and yes... I do have some wheel covers to minimize drag as well. The tires on the truck are already a commercial grade, high mileage tire rated for hauling heaving loads long distances for 100's of thousands of miles. The big killer for me is the gear ratio in the rear of the truck and the transmission. 4.10 gears in the rear and a 4L80e combined with a low C/R gas engine = shitty fuel economy. and rather than changing the gears out in the truck, I've found a much more viable option to swap the entire axle out instead. I can get a new set of gears for around $3-500.00 then spend another $3-500.00 getting them installed (cus I don't trust myself to do it correctly) and now I'm out $1000 which would take a good while to recoup the costs. Then depending on the ratio I went with, it would move the power around and I would lose a lot of the low-end that I love when towing, but I'd barely be turning the engine over on the highway. now, if I found the right axle from GM with 3.55's, I could pick that up for $2-400.00 and do the swap in my driveway and retain all factory components and if I "need" the taller gears for a heavy load, then it would be an afternoon to swap the rear back to the stock one and I could go back and forth whenever I needed without needing a specialty shop to pull apart my rear end. and considering that GM made a 14 bolt, 10 lug, 3.55 axle for their2500HD and 3500HD cargo vans, I'm sure I can find one relatively easy. Right now, its just getting the time to go looking is the hard part. that and I would have to retune the truck for the different gears (which would also let me update my speedo as well...lol) the axle swap would pay for itself in a few months (given the amount of miles I drive). doing a gear swap would take over a year to recoup and I would be stuck with whatever gear I picked and I like having the option to change things up for cheap. But, smoothing out the fog light ports on the lower bumper, opening one on either side to run brake ducting, then adding the 6" lower valence, and sealing off the open areas between the underside of the cab and the frame should help minimize some drag on the truck. Not to mention, I'm custom fabbing up a tonnau cover for the rear to work with my toolbox as well to aid in minimizing drag.
09-07-2012, 11:45 AM | #302 |
ace5.org
Sounds like you got a lot of work on your hands, but if you enjoy doing that sort of stuff then its no work at all!
Stock...For Now.
09-08-2012, 09:13 AM | #303 | |||
Truth Enforcer
the biggest thing is finding time to do it all. With a new house and a wife and kid at home and work being as busy as it is, time is a virtue. the good thing is, I'm patient.
09-09-2012, 12:28 PM | #304 | |
ace5.org
I know I'd like to be doing things with my car inside and out but the free time I do have I want to just be so lazy with school kicking my ass.
Stock...For Now.
12-01-2012, 11:58 PM | #305 |
Emerald Coast Camaros
Drives: 2014 ZL1 #77 Join Date: Jan 2011
Bump, same plan for fest 4?
12-02-2012, 12:02 AM | #306 |
I'll be in the Wednesday group this Fest. I'm assuming you guys will be taking the same route?
"I'm a man who discovered the wheel, and built the Eiffel Tower out of metal and brawn! That's what kind of man I am." - Ron Burgundy
My build thread |
12-19-2012, 08:04 PM | #307 |
ace5.org
I'm sure everything will be the same.
Stock...For Now.
01-12-2013, 06:03 PM | #308 |
Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
Just curious what the plan is for Fest 4. This is my first fest. I will be leaving early Wednesday.
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
SEPA5 Caravan to Camaro5 Fest III 8/2-4/12 | sscamaro | USA - NY / NJ / PA | 239 | 08-12-2012 10:00 AM |
CAMARO5 Fest III August 2-4, 2012 @ Lucas Oil Raceway, Indianapolis | KILLER74Z28 | 2012 Camaro5 Fest (III) | 1294 | 08-06-2012 11:00 PM |
Road trip to Camaro5Fest III from Oregon? | IOM Black Diamond | USA - Northwest / Pacific Northwest | 29 | 01-31-2012 11:31 PM |
TX Caravan to Camaro5Fest | chrisgalles | USA - Texas | 869 | 05-03-2010 09:01 AM |
Camaro5Fest caravan from greater Atlanta area? | cremaley | 2010 Camaro5 Fest (I) | 12 | 12-14-2009 11:07 AM |
