03-25-2020, 10:06 PM | #1 |
Drives: Camaro ZL1 Join Date: Jan 2018
Supercharger to head bolt snapped, where to urgently get a replacement?
Dear all, when fitting the ported blower, I snapped one of the supercharger to head bolts. I urgently need a replacement, as I got a date for a tune I cannot move. Where can I order a replacement bolt that would ship within 1 or 2 days? cheers cirpower
03-26-2020, 12:00 AM | #2 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Why not go to True Value and get a bolt there?
03-26-2020, 12:54 AM | #3 | |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showt...5#post10518225 Lots of info, part #s, shop manual pics, etc. on the subsequent pages. |
03-27-2020, 01:05 AM | #4 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Dealer. These bolts are single use and must be replaced. Sorry you didn’t see this in your other post asking for the torque and patten
03-27-2020, 01:06 AM | #5 |
NOXQCES ZL1
03-27-2020, 02:01 AM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
There are 10 total...with the sealing o-rings, I think you could get by without one of the fasteners...(temporarily!)
Torque is only like 89 inch/pounds...
03-27-2020, 07:23 AM | #7 |
If they are like the Magnuson's they are M6 bolts and mine torque at 108 inch pounds, GM might be less. When I worked for Magnuson a guy was bolting his down and snapping off all the bolts, he got confused about inch pounds and pounds. I got him straightened out and we sent him some new bolts.
03-27-2020, 07:44 AM | #8 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I could be wrong, but I find it hard to believe that those tiny ass little bolts are tty.
Baby Blue
03-27-2020, 08:37 AM | #9 |
If you need a single bolt run to the dealer. They will sell you a single bolt. If you order online they will probably only sell them as sets.
Also, I hope you can get the bolt out of the head....I believe the torque specs is 44in/lb first pass then 88in/lb second pass. |
03-27-2020, 01:30 PM | #10 |
Thanks everyone for the great help. I did re-use the OEM bolts, but for next time I would buy a set of new bolts for sure.
I broke one bolt (be careful, they break easily). Fortunately, they break further up and not in the thread, so I could easily remove it from the head. Home Depot sells an M6x95mm bolt (pitch 1.0) and that one worked just fine to replace the one I broke. I would definitely recommend to everyone doing this work to only use a small ratchet and be very very careful. cheers cirpower |
Thread Tools | |
