Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 03-30-2020, 04:16 PM   #29
Indy_62
Drives: 2017 2SS / 2003 S10 Crew Cab
The GM replacement battery for your vehicle is rated at 760 CCA, 70 AH
Never say never!
Indy_62 is offline   Reply With Quote
Old 03-30-2020, 04:55 PM   #30
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Here's a good one, have a 2012 ZLI, 10,000 miles with the original battery! and it's still strong!!!
2012 Victory Red ZL1
Lingenfelter 630 Package "Plus"
592 HP/580 TQ
BoostedX2 is offline   Reply With Quote
Old 03-30-2020, 05:02 PM   #31
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I keep my non-daily drivers on a tender. My batteries typically last around 10 yrs.
CW3SF is offline   Reply With Quote
Old 04-01-2020, 07:12 AM   #32
Yves ZL1
Drives: Canadian 2019 BLACK ZL1
So thť verdict seems she s toasted... do you think we can put one more powerfull ?
What would be a best one ? Isnít it dangerous for thť car ? Thanks
Yves ZL1 is offline   Reply With Quote
Old 04-01-2020, 07:46 AM   #33
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
What would be a best one ? Isn’t it dangerous for thť car ? Thanks
Read this thread:
https://www.camaro6.com/forums/showthread.php?t=572142
This forum member went with a slightly more powerful battery (800 CCA versus 760 CCA) and is happy with it so far. As long as the battery you pick is listed as a match for your car then you can use it.
476 rwhp/440 rwtq (sold)
Old 04-01-2020, 12:29 PM   #34
L78toLT1
L78toLT1's Avatar
I think I must have set a record with my Kubota Tractor. Bought it new in 2003, battery lasted until last spring! The original battery in my SS is still going strong at slightly over 4 years.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/GForce DS and axles/SEMA Grill/Rotofab dry/Pray ported TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned
Old 04-01-2020, 02:19 PM   #35
Yves ZL1
Originally Posted by SSDan View Post
Read this thread:
Great .... really Thanks
Because hŤre in France I think they are too big and Iím not sure it will fit ...🤔
Old 04-06-2020, 02:31 PM   #36
Yves ZL1
Hi another question...
Is there a trade that could send it to me in France ?
Do you know a website ?
Cause in france... no possibilities
Thanks guys for your answers itís urgent
Old 04-06-2020, 03:44 PM   #37
SSDan
SSDan's Avatar
I would just type this into your internet browser search function and see what comes up for availability and/or shipping options:
Optima Battery DH6 Group Size H6/LN3 800 CCA
This battery should fit and work with your ZL1.
Old 04-06-2020, 07:37 PM   #38
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
Come on, you are in Milwaukee I know batteryís freeze up there!
Originally Posted by JB'sZL1 View Post
Yes. Intense heat is far harder on a battery than intense cold.
Paintslinger16 is offline   Reply With Quote
Old 04-06-2020, 10:04 PM   #39
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Depends what parameter you are looking at.
For starting, cold absolutely kills batteries and reduces your cranking amps. I heard something like 20 degrees reduces it by half, but when we are talking -20įF, things can get interesting. I stupidly bought a lower-CCA battery for my Honda Pilot that seemed "enough", but after the first cold spell I couldn't get the damn thing to turn over and I started panicking, as in I had just replaced the battery and now this one was shot! Turned out it was fine (had it tested) and I had to turn off my lights, HVAC and radio...then it would start just fine, the cumulative effect of sucking amps away from starting was obvious, testing out the various draws, so the cold can have a big effect. That said, my Camaro has never given me a hint of trouble. I don't drive it when it's quite that cold, but definitely single digits occasionally. The cranking amps in the Camaro battery seems far more sufficient to crank and deal with various draws at the same time.
JamesNoBrakes is offline   Reply With Quote
Old 04-07-2020, 10:39 AM   #40
99BLKBRD
Drives: 2018 ZL1 Mosaic Black A10
Itís at a Canadian Dealership? If so, they should be obligated to replace the battery. In my opinion.
99BLKBRD is offline   Reply With Quote
Old 04-07-2020, 01:15 PM   #41
Yves ZL1
Iím gonna precise my request...
all what I found are us e-shops ... and the trouble is that they donít answer me... maybe because of the covid ...
So I need one that can ship it in France ... and this type of battery arenít sold in every shop...
But maybe you know other batteries that could fit ?
Bosch varta ??
Ití ll be easier to find it in europe.
99blkbrf : the trouble is that when the car is shipped ... The waranty is lost ...
Old 04-07-2020, 02:02 PM   #42
SSDan
SSDan's Avatar
Bosch varta ??
Sorry man - I am not a battery expert especially for France/Europe. So, I don't have much more help to give you. The only other thing I can think of is to get the battery dimensions from the Optima battery I linked earlier and then go to Bosch or whomever sells auto batteries in France and see if you can find a battery of the right dimensions that is an AGM (deep cycle)battery with at least 750 CCA. If it is an AGM battery that is the right size and it were my car I'd use it as long as it had enough cranking amps (CCA).
Good luck - I understand the no warranty issue.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
