Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 02-09-2010, 07:11 AM   #1
'69 Maro Man
'69 Maro Man's Avatar
Drives: 1969 Camaro
Virgin 69 Interior
This beauty has been untouched (interior) for 41 years. I found a mint 1969 quarter stuck in the dampening pad in the front passenger floor pan. I guess the worker was too envolved in laying the carpet to notice.
Replacing carpet, sound deadener, trunk divider and rear shelf then restoring door/rear panels and console. I did find excessive glue on driverside floor pan that was 3/4 in thick. Cleaning up pan which has minimal surface rust. Not sure what treatment to coat floor pan before installing pad and carpet. Any suggestions?
'69 Maro Man is offline   Reply With Quote
Old 02-09-2010, 10:07 AM   #2
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
Wow! That's pretty cool. What a beautiful, clean floor.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 02-09-2010, 10:22 AM   #3
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
looks pretty solid
Old 02-09-2010, 07:55 PM   #4
'69 Maro Man
Drives: 1969 Camaro
Bare floor
Here are shots of the floor pan without sound deadener pads. I need to finish cleaning the fuzz on the passenger side from the old pad. The carpet is scheduled for delivery on Friday the 12th.
Old 02-09-2010, 08:12 PM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Spray it with a product called "Metal Ready" to neutralize the surface rust. Then paint the floors with a product called POR-15. It is a epoxy paint, goes on easy with a typical paint brush. Both products are from the same company.
http://www.por15.com/
Fquick.com/NineBall
Nine Ball is offline   Reply With Quote
Old 02-10-2010, 04:02 AM   #6
'69 Maro Man
Drives: 1969 Camaro
Thanks nine-ball. I saw these products in a catalog from Classic Industries. Hopefuly a local paint store will carry POR-15.
Old 02-10-2010, 06:48 AM   #7
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
as the gentleman up above said Por-15 is some GREAT stuff just get ready to wear it for a few weeks lol is it very messy but gets the job done VERY VERY well. Good looking 69 btw !
Jekyll-N-Hyde is offline   Reply With Quote
Old 02-23-2010, 04:28 AM   #8
'69 Maro Man
Drives: 1969 Camaro
POR-15
Here are the latest pics of the POR15 epoxy applied to the floor pan and trunk. The dampening pads and carpet are next after I run speaker wires for new 6x9s being installed in rear shelf for upgrade over 1 speaker in dash pathetic sound.
To adhesive or not to adhesive? I was going to spray adhesive to underside of pads to prevent movement but when I was removing old pads I didn't encounter any sticky crap. What have you guys experienced in your cars?
Old 02-23-2010, 06:33 AM   #9
Jekyll-N-Hyde
Your POR-15 looks good Wow they have Gray now thats awsome !!!! The stuff I have used was black and it got on me and stuck to me for a few weeks no matter how much I scrubbed.
You did a good job applying it how thick did you apply it ?
I'm sure this car wont be out in the rain/Snow anymore so to be honest you are just being cautious with using por-15 which is not a bad thing these cars dont drain like a NEW car.
My Carpet is not glued down if you buy a good quality carpet from like year one or Classic industries it sits pretty tight on the floor with no wrinkles or buckles. While you have the carpet out I would lay down a line layer ( padding , sheets or spray which ever one you choose to use all work ) of dynamat sound deadener. If you still want to hear your exhaust use it thin however I wish I had used this plus it protects from the heat/moisture on your floor. Your exhaust will be right under your driver/passenger floor pans so you will hear your exhaust if you go with a louder muffler.
I got a Bigblock I hear mine
Good Luck !
Old 02-23-2010, 06:58 AM   #10
Dr Jkel
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man
I would use the POR 15 on the entire floor and all metal, it is a rust inhibitor and will help tremendously. I have had luck with Dynamat, it works great, Very Nice Car.
Dr Jkel is offline   Reply With Quote
Old 02-23-2010, 08:17 AM   #11
Nine Ball
Nine Ball's Avatar
I've never had carpet movement issues in my 1st gens, don't need adhesive. Just be sure to use OEM type replacement carpet kits, not do-it-yourself non-fitted carpet.
Fquick.com/NineBall
Old 02-24-2010, 03:53 AM   #12
'69 Maro Man
Drives: 1969 Camaro
Smile Thanks!
Thanks Jekyll, Dr. Jekel and 9ball for your advice and compliments! I did purchase the preformed carpet from Classic Industries so I will go au naturale and let the door sills and console hold it in place. As for covering all of the metal with POR15, I plan on finishing the job. My daughter came home so I had to take a break.
The pads I'm using are the stock replacements from Classic Industries that are made from the same material as roofing shingles. I decided to just lay them in place except for the 2 under the driver and passenger seats that are prone to movement. I will tack then in place with a little adhesive.
Would it be overkill to use Dynamat with the the OEM pads?
Old 02-24-2010, 04:03 AM   #13
'69 Maro Man
Drives: 1969 Camaro
Dynamat over Flowmaster
Good Luck !
I do have Flowmaster 30 series which are loud so I just might go for Dynamat so I can hear my newly installed rear speakers.
Old 02-24-2010, 06:16 AM   #14
Jekyll-N-Hyde
If you do use the dynamat and you use the liquid use just a little therefore you can still hear the rumble of the exhaust and hear your stereo.
The paper dynamat works great for speaking elcosurs in the doors but thats about it.
Something I dont get about the interior of this car?! Blue Maro Demon 5th Gen Camaro SS LS LT General Discussions 82 08-12-2009 11:03 PM
Re-do Interior with gen5 Interior? any help RussJabZ28 USA - Texas 1 08-11-2009 01:08 PM
interior color choice armando416 Camaro Price | Ordering | Tracking | Dealers Discussions 31 03-25-2009 10:39 AM
Interior Question TomServo 5th Gen Camaro SS LS LT General Discussions 1 03-04-2009 08:48 PM
Firsthand report: just sat in two Camaros at the Cleveland Auto Show Attorneyguy 5th Gen Camaro SS LS LT General Discussions 154 03-01-2009 09:40 PM
