Old 10-11-2023, 09:18 PM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
CONGRATS ON THE GREAT TIMES!!!
'20 ZL1 Black "Fury"
Old 10-23-2023, 11:20 AM   #16
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I made it back to the track and got a new pb! 9.28@153. Shift points were off since last time out so I datalogged and tried making some changes to improve the time with the same power in it. Boost controller has been targeting the same 10lbs of boost since Indy but it’s been creeping up into the 11-12 range. By the end of the day I got shift points where I wanted and it actually slowed down to 9.38@152. The biggest difference is in the front half. As others have suggested I think I need to leave the converter unlocked longer. Trying to lock in 2nd it slips the first half of the gear then gradually gets there by the end. Kind of weird it’s not commanding as high of pressure as it does in the higher gears. It unlocks for the 2-3 shift then slips trying to grab and eventually does then stays holding the rest of the way down. Think im going to try unlocked for longer next time out. I also need to get it to build some boost on the line. Leaving off 2 step at 2500 rpm and 101kpa right now.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 10-23-2023, 11:47 AM   #17
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Congrats! Getting that 60’ time down is paying off.
Old 10-23-2023, 12:08 PM   #18
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 10-23-2023, 12:27 PM   #19
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Looks like it's all paying off dude, your car is moving out! Congrats on your PB and it looks like there's more to come
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Dynamical is offline   Reply With Quote
Old 10-23-2023, 07:17 PM   #20
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Damn that thing is quick, great pass bud.
lt4camaro is offline   Reply With Quote
Old 10-24-2023, 07:05 AM   #21
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Man your front half is killing you, back half is hauling the mail. Congrats on a really great pass. You'll get if figured out and 5 second 1/8 mile is coming soon, then hopefully some really low 9 second passes. Maybe 8s?
Old 10-24-2023, 08:35 AM   #22
jlaudio11
jlaudio11's Avatar
I feel like I have enough power in it to go 9.0/8.9 and yes I'm trying to get everything working together better before just throwing more power at it.
Couple months ago on a front side no prep, 2nd gear launch and leaving on boost it was on the verge of shaking the tires, definitely vibrations going through the drivetrain and I let out of it. I have hendrix offset diff bushings and solid cradle bushings sitting in the freezer but I haven't gotten them installed yet. Hopefully that will happen sooner than later, and next time out I'll try to get after it harder out of the hole.
This trip to the track I was trying to get shifting and converter lock up working how I wanted and didn't want to mess with too many things at once, like messing with launch rpm. It'll get there eventually!
'20 Camaro LT1
Old 10-24-2023, 08:44 AM   #23
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Solid run! I would probably bump the converter lock to 4th gear. The slipping is no bueno at your power level. Will kill the trans quick.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-24-2023, 09:25 AM   #24
jlaudio11
jlaudio11's Avatar
That’s what I was thinking, 4th or even 5th depending on which is quicker. The converter definitely coupled more before lock up this past time out compared to Indy. So it will carry the gears longer now.
Wish I could upload video here but the forum platform isn’t great for it.
'20 Camaro LT1
Old 10-25-2023, 07:17 AM   #25
laynlo15
laynlo15's Avatar
You are so close to a 9 second pass, when it happens your going to be one of the elite Camaro's that's done this. It's not easy putting it all together in one pass, I think your going to do it real soon. Go get ya some 8s.
Old 10-25-2023, 06:27 PM   #26
jlaudio11
jlaudio11's Avatar
Thanks for that. I keep looking at the fast list and what other people are doing, basically thinking I’m slow lol. Low 9’s closing in on 8’s definitely isn’t a bad place to be!
Here is a quick video of this last Sundays tnt. My fiancée ran the F150 and had a ball while I ran the Camaro. She drives the Camaro (took it to work yesterday) but is starting to itch to put it down the track. Maybe this year but probably next year, at which point I’m probably going to have to really start looking into building something faster for her lol.
https://youtu.be/A0ozvBzbQuI?si=hPFARTQCPZ3M0YBy
'20 Camaro LT1
Old 10-25-2023, 06:42 PM   #27
Joshinator99
Ugh, I know the feeling….
