03-20-2019, 12:35 PM | #15 |
Drives: 2018 Camaro 2SS 1LE Join Date: Dec 2006
One of my very best friends has a 2015 ZL1 which I drove and loved it. Then I got myself a 2018 2SS 1LE last summer and the performance is pretty much identical according to my butt dyno. But the 5th gen ZL1 is a bigger and roomier car than the 6th gen, has more storage space, bigger trunk and is definitely a more comfortable daily driver, especially for bigger, taller people. As much as I love my 6th gen SS 1LE, I find it harder to get in and out of than my 2014 Mustang GT and my good friend's 5th gen ZL1.
03-20-2019, 12:40 PM | #16 |
Drives: 2017 HBM ZL1 Join Date: Feb 2019
My credit union would only finance back to 2014 and me personally hated the rear end styling on the 14-15 ZL1's. I had a 13' ZL1 and that's what I wanted, I saw the new 19' SS and didn't like that either so after that there was one logical choice. I found a great deal on a 17' ZL1. Like stated above though, the ZL1 def has the rarity factor and although same power levels as a new SS is already boosted so exhaust and some pulley changes can be making way more power for cheaper, just my .02
2017 HBM ZL1-M6-RotoFab CAI, 2" TSP LT's, 9.84 Lower, 2.30" upper, Kong X port SC, PRC heads/cam, meth/alky injection, DSX aux fuel system, W/E-900.2/875.6
03-20-2019, 12:59 PM | #17 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
The bigger question is 5 or 6 gen. These vehicles are like apples and oranges. It’s true that the gen 6 is smaller but otherwise has been improved in every way. I recently sold my 15 SS and bought a 17 SS and love it. That LT1 is fab with a Magnaflow axle back!
Sent from my iPhone using Tapatalk |
03-20-2019, 01:43 PM | #18 | |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
03-20-2019, 02:17 PM | #19 |
Drives: 16' Camaro E-Force SS Join Date: Jul 2016
The biggest factor no one has mentioned is how long do you plan on keeping the car? The SS will depreciate like a freight train, the ZL1 will not.
If you plan to sell in the next couple of years, can you take the hit on a new car? You could also get a better looking 2019 SS for less money by buying a used 2017/18 1LE. That to me would be the sweet spot. Depreciation has happened, same performance as ZL1 and 19 SS, without the hideousness that is the 2019.
Leo
2016 e-Force 2SS Instagram @cleoent |
03-20-2019, 02:35 PM | #20 |
Drives: None yet Join Date: Mar 2019
I plan to run the car into the ground, I don't sell cars. Depreciation is not a huge factor just want something I love and will last.
My truck is a 2006 F150 bought new, still looks and works great. Has 180k miles, looking to get a good 20 years out of it (goal anyway). I'll rebuild the engine when it goes. The car I would keep a minimum of 10 yrs. THis is one reason I'm leaning toward the new car. The ZL1 would already have 6 years on it, but I guess if it's solid (no rust, low miles) it would be OK. The camaro would get around 15k miles/yr on it. Mostly highway. |
03-20-2019, 02:47 PM | #21 |
Drives: 2018 1SS 1LE Join Date: Apr 2018
17-18 1SS 1LE's seem to be going for around 34-38k depending on mileage.
I seem to be the outlier here, but I really dislike the 5th gen styling. Love the 6th gen, though.
2018 1SS 1LE (sold) |
03-20-2019, 03:12 PM | #22 | |
To me the 5th gen looks more boxy and brutish, like a muscle car. I like them both. |
03-20-2019, 03:18 PM | #23 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
Go with the 2019 1SS you won't regret it. I would definitely not spend 35k on a 6 year old car, no matter how powerful it is. The 1SS will be a much better car in all ways.
03-20-2019, 03:34 PM | #24 |
this would be a tough choice,maybe you should check out the ZL-1 prices/mileage and compare them to what the newer SS would cost.or how about a year old SS CPO car if you can find one you like and save a significant amount of money.
03-20-2019, 09:53 PM | #25 | |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
03-20-2019, 10:06 PM | #26 | |
'16 Camaro SS
03-20-2019, 10:21 PM | #27 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
'12 ZL1: 6.98 lbs/hp '19 SS: 8.33 lbs/hp The '19 SS would need another 88 hp (543 hp in a 3,788 lbs SS, per Car and Driver '19 A10 test data) to match the ZL1 lbs to hp ratio. I theorize the '19 SS is nearly identical in the 1/4 mile and 0-60 because of traction control and the A10 (and rev match for the M6), and likely a more efficient drive train putting more effective % of the crank power to the wheels. I looked at acceleration times between the '19 A10 SS and the '12 ZL1 and they were nearly identical: the ZL1 was only 0.1 second faster to 60 mph (3.8 sec vs 3.9), to 100 mph (8.7 sec vs 8.8) and in the 1/4 mile (12.1 vs 12.2). I think the manual SS is a tenth or two slower in each of those vs. the A10 SS, but almost as fast. Trap speed in the M6 is definitely lower (115 mph vs. 118 mph). The 5th gen ZL1 traps around 118 mph. It baffles my mind that a car with that significant of a lbs:hp ratio advantage is barely quicker than the much less powerful car. If you were to add 88 hp to the '19 SS, it would flat out destroy the 5th gen ZL1. So, to me, I would pick the '19 SS over the ZL1 - likely safer, newer (obviously), nicer interior, warranty, probably better gas mileage (I haven't confirmed), more modern tech., and with full bolt-ons would be quicker than the supercharged 5th gen ZL1.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
03-21-2019, 06:01 AM | #28 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
The gen5 ZL1 curb weight started at 4,120 lb
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
