Old 11-14-2016, 09:00 AM   #29
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Originally Posted by Michigan1LTRS View Post
I sent Jason@Jacfab a message to look at this. He will know what to do.
Right on brotha. Keep me updated.
whiskeyfed is offline   Reply With Quote
Old 11-14-2016, 09:02 AM   #30
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
I sure will.
Old 11-14-2016, 10:17 AM   #31
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Injen Evo7300 Cold Air Intake for the 2.0 Camaro!
The tube on my 16 is definitely different than yours. Did you try squeezing that pad area in front and back below the slot with your fingers and pulling?
I wonder if this is GM's a way of trying to make sure no one installs an aftermarket intake? There is a small chance that it may not even come off at all? A one shot deal. Worst case scenario oh, you may have to buy another one, or maybe buy one from a 16
Old 11-14-2016, 10:21 AM   #32
whiskeyfed
Pat
whiskeyfed's Avatar
I am going to go out to my car on my lunch break and see what i can do. Hopefully it is just a squeeze and pull.
Old 11-14-2016, 10:30 AM   #33
Michigan1LTRS
Blessed ❤️
I checked it out. It wont squeeze. I also noticed on the backside there is the exact same hole and raised pad area. Never seen anything like it.
Old 11-14-2016, 10:33 AM   #34
whiskeyfed
Pat
whiskeyfed's Avatar
[QUOTE=Michigan1LTRS;9404663]I checked it out. It wont squeeze. I also noticed on the backside there is the exact same hole and raised pad area. Never seen anything like it.[/QUOTE
Old 11-14-2016, 10:33 AM   #35
Michigan1LTRS
Blessed ❤️
In the end you could just remove the hose from the engine side and replace with hose and clamps. It wont look OEM, but should work although I have not looked at how the engine side is clamped. Hopefully not the same way.
Old 11-14-2016, 10:52 AM   #36
Michigan1LTRS
Blessed ❤️
I got a part number from ThatGMPartsguy for the GM cold air kit coming for the turbo. I believe this is what I will order when it comes out. It will be interesting to see what their instructions say about this.
Old 11-14-2016, 10:53 AM   #37
Jason@JacFab
Might need something like a fuel line disconnect tool to get it off?
Old 11-14-2016, 11:00 AM   #38
whiskeyfed
Pat
whiskeyfed's Avatar
This looks right, i might go and pick one of these up today. BTW Chevy customer repair service has no clue what they are talking about. I called and the guy had no clue what i was talking about and then hung up on me...
Old 11-14-2016, 11:10 AM   #39
Michigan1LTRS
Blessed ❤️
Man, I hope this works. I'm really not surprised the dude had no clue to help you.
Old 11-14-2016, 11:17 AM   #40
Jason@JacFab
They usually come together in a kit of various sizes for like $10 or less. From looking at your picture they will have to be fairly short ones
Old 11-14-2016, 12:12 PM   #41
whiskeyfed
Pat
whiskeyfed's Avatar
you think something like this would work?
Old 11-14-2016, 12:15 PM   #42
Jason@JacFab
yes, that's what I'm thinking may work.
If that doesn't work, I'm sure gm has some dumb specialized tool to undo it because they don't want joe public to mess with it. That, or it's permanently connected like I mentioned earlier, just a one shot connector.
